Mariah Z 272 Barchetta 1995
Old 11-12-2014, 01:42 PM   #11
Hudson River Steve's Avatar
My Model: Z280
My Engine: 7.4L MPI Bravo3
Send Hudson River Steve:
Default Re: Mariah Z 272 Barchetta 1995
There are oil absorbent products out there to place in the bottom of your bildge that absorb oil but not water. You should also add some bildge soap each time you use the boat. The combination of these two should get rid of most of any lingering oil. If you continue to find additional oil then you will know the answer to question #2...BTW a quart every couple of hours seems excessive to me.
Hudson River Steve
1999 Z280
7.4 MPI, Bravo3
  • Old 11-13-2014, 02:23 AM   #12
    LOTO Z240 Talari's Avatar
    LOTO Z240 Talari is currently offline
    My Engine: 454 Mag BR1 GenV 365hp
    Gallery Images: 29
    Send LOTO Z240 Talari:
    I have a 1995 7.4L 454 Magnum. The total engine hours are 890; we used the boat 40 hours this past season. The total oil consumption for the 40 hours of use was less than 1 quart. More like a little less than 3/4 of a quart. I feel what you are experiencing is very high, but would like to hear other opinions.
    LOTO Z240 Talari
    Old 11-17-2014, 10:48 PM   #13
    mikesnowman's Avatar
    mikesnowman is currently offline
    My Year: 97
    My Model: 272 Shabah
    My Engine: 7.4 mag
    Send mikesnowman:
    I would look at the oil pan gasket or drain plug to see if it is dripping. There is no way an engine should use that much oil. If the rings were not done right it could burn that but you would see it in the water or out the exhaust. This explains the oil in the bilge.
    How did I do? First Boat 1995 Barchetta Z192? jkboliphant Original Mariah Talk 4 02-27-2009 01:40 AM
    1995 Barchetta 182 peppe Original Mariah Talk 6 06-06-2008 06:13 PM
    1995 Barchetta 182 chippat Original Mariah Talk 1 10-01-2007 02:39 AM
    1995 Barchetta 182 chippat Introductions 8 08-30-2007 08:12 PM
    There are 313 users
