buying a prop need help
Old 04-20-2009, 01:42 AM   #21
greencanuck is currently offline
My Model: 2002 Z245 Jubilee Mid Cuddy, 6.2LMX Bravo III
Send greencanuck:
Default Re: buying a prop need help
I have one in aluminum 13.75" 3 blade 21P. I can find out what there are worth and work you a deal if your interested. Where are you at?
  • Old 04-28-2009, 03:45 PM   #22
    22empire is currently offline
    My Model: 2000 Shabah 183 4.3L Alpha
    Send 22empire:
    I just saw this.. I am in Barrie, and I would be interested in a prop. I need to see if there is a spare in the boat when I pick it up on Saturday regardless...
    Old 04-28-2009, 04:28 PM   #23
    Eddie is currently offline
    My Model: 1994 Z241 davanti 454
    Send Eddie:
    Just to throw this out there because it happened on my bass boat! My prop was slipping and after some discussion and looking from a local prop guy (Old guy with lots of knowledge), all he did was put a lip on the backside of every blade which in turn caused the prop to catch more water, in return no slippage!
    Old 04-28-2009, 08:19 PM   #24
    Yep, i've seen that work. That's why prop blades with more pronounced 'cupping' tend to perform better. You can go too far though.....
    Old 05-01-2009, 04:36 AM   #25
    Irace82's Avatar
    Irace82 is currently offline
    My Model: 1993 Shabah 198 4.3LX Alpha I
    Send Irace82:
    One more question about buying a prop. Do i need to take the prop off and determine how many splines there are or should it be universal for a set type of outdrive? And also when i order one does a hub come with it to match it?
    Old 05-01-2009, 10:50 PM   #26
    It depends.....some places sell the hub kit as part of the prop package & some places separate the two. If you look at the i-boats site, they tell you what hub kit you need for each prop and application.
    Old 05-04-2009, 10:02 PM   #27
    cleah is currently offline
    Send cleah:
    Hi,
    I have a 1993 2350Z with Merc 7.4 and Bavo 1, but unusaul outdrive lower with oil drain hole behind prop/ It had a 4 blade 15.25" dia 15" pitch prop. The max rpm is quoted at 4800 for the engine, but it will easily exceed this if I let it. Does this mean I need to go to higher pitch? I am relatively new to baits and am learning as I go. I forgot to mention that the boat also has the switchable option for through transom exhaust. Any advice is welcome. I guess I should also mention that I am in Utah and the altitude where we sail is usually around 5000 ft.
    Clive
    Old 05-04-2009, 11:34 PM   #28
    z275st's Avatar
    z275st is currently offline
    Gallery Images: 33
    Send z275st:
    Originally Posted by cleah View Post
    Hi,
    Clive
    Yes, that makes a big difference. My boat was from CO where it had a 19"p prop. Here in IL I use a 23" You may also have a 1:1.65 gear ratio also. It does sound like your under pitched on that prop, a 17"- 19" may work but in hot humid weather you may need to switch back to the lower pitch.
    John
    2001 Mariah Z275st
    496HO Bravo1
    Buying a Mariah tomorrow JoshuaHynes Introductions 42 08-23-2010 11:15 PM
    Thinking of buying my first boat! kw98mariah Introductions 10 02-07-2008 05:23 PM
    Thinking of buying my first Mariah TnBoats Original Mariah Talk 4 01-12-2008 01:59 AM
    Buying my first Mariah this weekend golfballdiver Introductions 12 01-08-2008 04:44 PM
    There are 250 users
