What are the fuses under the dash for? Z216
Old 04-03-2009, 07:14 PM   #1
anthonybradley is currently offline
My Model: Z216 '97 Merc 5.7l Alpha one.
Send anthonybradley:
Default What are the fuses under the dash for? Z216
Hi,
Just going thru tidying up the electrics in my Z216, and am unsure what items the 6way 'blade' type automtive fuse block under / behind the dash feeds? It must be somthing serious as there is a 15A and a 30A fuse amongst others. Its powered from a cable thats fused into the battery switch common terminal, thus whatever battery the engine is switched to.
Is there a proper circuit diagram for these boats other than the harness layout in the manual?
I currently have the engine out so ignition etc is disconnected; are all the nav lights, wiper etc etc are all powered from the engine loom? As they don't currently power up and the looms are so tightly packed in its very hard to get to or trace cables.
UPDATE - just found some circuit diagrams in the archive section, they show the fuse block but not what it feeds.
Thanks!
Anthony
  • Old 04-05-2009, 09:46 PM   #2
    Default Re: What are the fuses under the dash for? Z216
    So it seems nobody else knows either?
    FYI I have traced several of them, one is fan in cabin, one is electric aerial, and another is electric helm seat.
    Oh and yes just about everything is powered by a supply from the engine loom, so if you ever loose dash power check the circuit breaker on the engine.
    And my final tip for the day, the trim pump has a fuse built into that little red plastic square where the positive power lead attaches to the relay unit next to the pump. So if you lose power trim it maybe that, mine was corroded so partly flaked away, not sure how long it would have lasted.
    Hmm well seems I am talking to myself here, anyway hope that info helps someone someday!
    Anthony
    Old 04-05-2009, 10:16 PM   #3
    z275st's Avatar
    z275st is currently offline
    Gallery Images: 33
    Send z275st:
    Hey Anthony , Did you say something?
    Seriously, I don't think anyone is ignoring you, but only someone with your same boat may know the answer, they may not have read it yet, may not know, or may have the same question and you just helped them out.
    We are all about trading info here and helping out when we can.
    John
    2001 Mariah Z275st
    496HO Bravo1
    Old 04-05-2009, 10:25 PM   #4
    Hi Anthony,
    Sorry if it seemed like you were alone, your not, and as z275st said, you may have been dealing with an issue our other members haven't experienced yet. I'm sure sometime in the future, your post will definitely help one of our members too!
    All in all, I want to thank you for passing along what you discovered with your fuse bank, engine loom and trim pump fuse. Most of the information we gather is through members like yourself, troubleshooting a issue and documenting what they find and how they resolved them.
    When it comes to boats in general, the electrical systems seem to be the most mysterious and documentation is very elusive indeed. It becomes more difficult when there are so many different models, each with possible unique setups to deal with. As you and other members have shown, some of the Cabin models appear to have the most complicated wiring.
    I think in the future, especially when we have to deal with electrical issues, If we can all remember to take a little more time to diagram and photograph the circuit or fuse layouts and post them on the forum it would be invaluable to other members.
    Thanks again,
    Old 04-06-2009, 06:44 PM   #5
    Sorry I mean for that to sound so abrasive, it was late at night and I wasn't to sure anyone else was an interested in the inane detail of a fuse board or trim pump fuse as I can be
    There are several collections of circuit diagrams in the archive on this site, but having studied them I would say use them as a guide only, they are not exact, and obviously changed over time / model; but certianly a good place to start if you want to understand your wiring.
    Anthony
    Wanted: Question - Inline Fuses Douglas Alderman Mariah Parts For Sale & Wanted 9 12-30-2013 01:11 PM
    Mariah Z216 MMarko Original Mariah Talk 2 03-08-2011 02:06 PM
    Z216 MMarko Original Mariah Talk 3 01-29-2009 08:28 PM
    Trailer for a Z216 anthonybradley Trailering and Tow Vehicles 4 10-02-2008 02:53 PM
    “Minor” problems with fuses, trip odometer, trim gauge scotty65 Original Mariah Talk 7 05-31-2008 11:35 PM
    There are 247 users
