Mercruiser Shifter Recall
Old 09-09-2011, 01:06 AM   #11
Hudson River Steve's Avatar
My Model: Z280
My Engine: 7.4L MPI Bravo3
Send Hudson River Steve:
Default Re: Mercruiser Shifter Recall
Here is a good site that explains the operation of the entire shift system.
Replacing your Alpha One shift cable.
I had an older boat with an Alpha One drive that had the same problems. The shift cable out to the drive had worn through the outer casing where the exhaust exits the boat, when I put pressure on the shift cable it would kink slightly and cause excessive friction on the cable. This would cause the spring loaded shift plate to rotate, activate the kill switch and cause the boat to stall. I replaced the shift cable to the drive, adjusted the microswitch and it shifted like new.
Hudson River Steve
1999 Z280
7.4 MPI, Bravo3
    Shifter issues RPOLS3 Original Mariah Talk 6 09-03-2011 05:11 AM
    Throttle Control - Mercury recall bdbyrnes Original Mariah Talk 2 09-02-2011 08:39 PM
    Recall Letter peppe Trailering and Tow Vehicles 18 09-01-2008 03:35 PM
    Another thottle shifter ? 01DiabloMissouri Original Mariah Talk 4 04-25-2008 02:38 PM
    There are 302 users
