Need Help From A Mariah 212 or 211 owner
Old 09-05-2011, 02:25 AM   #1
Atec is currently offline
My Model: Z211 Shabba
My Engine: 5.7
Send Atec:
Default Need Help From A Mariah 212 or 211 owner
They may also be some other models that could help as well .
The back seat on boat when lifted ,three seats all together as one,have a drain plug going down through right and left side bottom ,to the carpet on floor. I noticed that the is no hole under the carpet on my boat. I cut away the carpet today. Can any one shed some light or be able to take o picture or there floor if it has a hole. I dont want to take a chance running a drill bit down through floor until I get a confirmation.
My boat is a 1995 Z211
  • Old 09-05-2011, 03:24 AM   #2
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    Default Re: Need Help From A Mariah 212 or 211 owner
    Ours is similar, Its at the lake so I could see tomorrow but from memory the hole is only in the seat section an not in the floor itself. I can tell you for sure there are no holes in my flooring below that seat as I had it forward a lot this winter and would have seen them easily as that was my work station for about 20 hours.
    I never really thought about it needing to drain. I am certain mine will never be full of water unless we are going down.And then I just hope the bilge pump keeps up till I hit the shore!
    Hope that helps
    Zack
    1994 Z212 Shabah
    Thank you Zackattack for this useful post!
    Atec (09-05-2011)
    Old 09-05-2011, 10:32 AM   #3
    93Shabamag is currently offline
    My Model: Shaba 212
    My Engine: 350 Mag Alpha 1
    Send 93Shabamag:
    I have a 93 Shaba 212 and have had the seat unhinged to work on motor. I assumed the seat just drained to bilge via floor, I don't have a hole in floor. Makes me think, should I be proping seat forward after day of tubing and skiing to let floor dry under bench? I think there is two metal strips on floor to create drain and air space at back of seat. I would not think drilling a hole will help, the gas tank is back there.
    Thank you 93Shabamag for this useful post!
    Atec (09-05-2011)
    Old 09-05-2011, 03:39 PM   #4
    My Engine: 5.7
    Send Atec:
    Hope that helps
    Thanks Buddy , I think you are Corect. There is no floor drain, i found a older post last night. When i purchaseed the boat a month or so ago . I scrubed and washed down everything . Thats how water got in there. Of course it gone now but was suprised too see how long it took to drain.I think i will keep the seat up about a 1/8 from floor next time if i ever need to clean so water can drain right out. I think that was a stupid design.
    Old 09-11-2011, 01:51 AM   #5
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Since I keep mine in the garage, I take the stuff out of the seat compartments and leave them open to dry. I also have a small block of wood I use to prop up the seat to allow air to get between the seat and the floor.
    My boat looks like a dump for a few days, but then I put it all back together when I know it's dry.
    New Mariah owner garethjo Introductions 4 09-20-2010 05:43 PM
    Possible New Mariah Owner of Z-225 MadMax Introductions 2 09-04-2010 02:04 PM
    New Mariah owner! theeasynine Introductions 4 09-01-2010 12:33 AM
    new owner mariah roger56 Original Mariah Talk 1 12-28-2008 01:07 PM
    another Mariah owner illini1 Mariah Boats For Sale & Wanted 3 08-25-2008 08:47 PM
    There are 337 users
