Parts !!!!
Old 01-17-2009, 02:04 PM   #1
clockwood is currently offline
My Model: 1996 z210 Talari 5.7 Alpha I
Send clockwood:
Default Parts !!!!
I am looking to replace my dash panel on a 1996 z220 Talari. Does anyone have an idea where to start? The part I am looking for is panel that holds the stereo head unit and houses some other switches.
  • Old 01-17-2009, 05:45 PM   #2
    They are known to occasionally show up on ebay. But those parts were made in-house at the old Mariah plant, and the when they closed up, the molds and all the spare parts were auctioned off, so honestly they're REALLY hard to come by, and might not even exist anymore.
    Your best bet is to get it repaired, contact your local plastic fabricator, and see if they can help. If they can't, post back and we'll see if we can help you out. This seems to be a pretty common problem with those models.
    Old 01-17-2009, 10:55 PM   #3
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Are you talking about the panel down below where the stereo is? You might want to have a look at this thread:
    http://www.mariahownersclub.com/foru...ead.php?t=1340
    One of the contributors on here gave plans to make an aluminum replacement piece. I don't know if the size is different, but you might be able to use it. I cut one and used it as a backing plate for my existing one. It wasn't in too bad shape, but it had cracks appearing in it. Another idea is to get one cut, powder coat it and use it as a replacement.
    My Mariah
    Old 01-19-2009, 12:18 AM   #4
    Send clockwood:
    Default water temp
    i have a water and air temp digital guage. The air temp works fine but the water temp doesn't. do you know where the temp sensor is or what might be wrong with it?
    Old 11-15-2012, 05:08 AM   #5
    seanjenny is currently offline
    My Model: z240 Talari
    My Engine: 7.4 Bravo III
    Send seanjenny:
    Default Re: water temp
    Heya clockwood
    I have the same problem but the air temp does not work and the water does. I am still looking, if you find out anything could you let me know and I will do the same
    seanjenny
    Old 11-15-2012, 12:45 PM   #6
    Originally Posted by seanjenny View Post
    Heya clockwood
    seanjenny
    This thread is almost 4 yrs old....
    Old 11-15-2012, 09:59 PM   #7
    aubtiger's Avatar
    aubtiger is currently offline
    My Engine: 7.4L Bravo I
    Send aubtiger:
    Default Re: Parts !!!!
    As far as the radio housing I made one out of 1/8 aluminum sheet. Got the graphics scaned. Looks great and I'm going to powder coat it flat black and put the graphics on it. Looks better than the factory one. Will not ever brake or rust.
    98 Mariah Parts jagels Original Mariah Talk 11 07-17-2020 01:39 PM
    Wanted: Parts need for z222 DONNA Mariah Parts For Sale & Wanted 4 11-06-2008 11:38 PM
    Some parts impossible to get adornare Original Mariah Talk 3 06-25-2008 04:47 AM
    OEM parts tnmc13 Original Mariah Talk 6 02-09-2008 11:23 PM
    Used engine parts MariahShabah3.0 Mercury MerCruiser 0 08-29-2007 12:32 AM
    There are 240 users
