Water Pump Replacment- Alpha Gen2 DIY??
Old 06-28-2008, 05:35 PM   #1
kadasia's Avatar
kadasia is currently offline
Gallery Images: 2
Send kadasia:
Default Water Pump Replacment- Alpha Gen2 DIY??
All: I am considering doing this myself. The manual talks of two "special tools" oil seal driver Part Number 91-817569, looks like a two sided driver for setting seals at correct depth, and PN 2681657A2 to replace the pump shaft water pump seal.
Outdrive is 1998 Alpha 1 Generation Two. The water pump is the sea water pump with the Stainless housing.
Question: Can Special tools be made? Any recommendations on purchase? Pictures of special tools?
Tips traps techniques and suggestions ALWAYS welcome!
Many Thanks
Dave[/FONT]
  • Old 06-28-2008, 09:20 PM   #2
    Hi Dave,
    I don't know if this will be the same for the 98 Alpha but accordind to the 97 alpha manual, it states that: "NOTE: Water Pump Face Seal Tool is not available separately, 26-816575A2 is a kit part number which includes the tool and the face seal." which is the tool I believe you're referring to.
    I would contact your local Merc parts dealer and inquire if your kit includes this tool (91-817569) as I believe the 97 and 98 gen II's are the same.
    Good luck,
    P.S. here is a link to Sterndrives.com, they mention the tool that comes in the kit: "The Gen II water pump kit comes with a little slinger seal installation tool. It's really just a small plastic cup. ".
    Last edited by WetWilly; 06-28-2008 at 11:16 PM. Reason: Added additional info... WetWilly
    Water pump for sink [email protected] General Maintenance 5 03-23-2015 06:01 PM
    Bilge pump issue adornare Original Mariah Talk 12 03-29-2010 03:30 AM
    1998 Z252 Auto bilge pump replacement edward cossey Original Mariah Talk 2 06-09-2008 06:41 PM
    Seawater pump impeller Paul Z General Maintenance 1 05-01-2008 02:50 AM
    There are 363 users
