Gas tank leak
Old 07-01-2013, 09:51 PM   #21
stlawerance is currently offline
My Year: 1985
My Model: 190 Talari
My Engine: 3.0L Merc
Send stlawerance:
Default Re: Gas tank leak
will do, thanks for the info
  • Old 07-10-2013, 05:08 AM   #22
    My Year: 1985
    Send stlawerance:
    Well, got the leak all sealed up. Havn't seen the handy work yet but I am told it looks pretty good for a temp fix. Also found a leak in the lower unit oil reserve tank, anyone know where I can order a new one from?
    Old 07-11-2013, 12:42 AM   #23
    Here you go stlawrance
    Trim Pump Oil Tank.
    Old 07-11-2013, 01:01 AM   #24
    My Year: 1985
    Send stlawerance:
    It appears that this has a different shape then mine, I was thinking it was more vertically tall and slender. I will have to ck when I get back up to NY at the end of month. Is there another option for the Mariah, I have a 190 Talari 1995. Thanks for the info.
    Old 07-11-2013, 01:04 AM   #25
    Might be the newer version.
    Let me look.
    Do you have the Engine/Drive ID number?
    Old 07-11-2013, 01:08 AM   #26
    Just checked and they are all the same part # from 1991-1997.
    #18525A1 is the part number.
    Old 07-11-2013, 02:42 AM   #27
    My Year: 1985
    Send stlawerance:
    I am sure you are correct I am going off memory from last yr, at my age it isn't as good as it use to be. Thanks for the info. I was also told from the previous owner that the tank was just replaced 2 yrs ago, is this a known problem with these tanks?
    Old 07-11-2013, 02:49 AM   #28
    Sounds like you better check the Trim Motor Mount. They are known to corode and break , letting the weight of the assembly ride on the tank.
    If so , stainless steel is the way to go.
    Trim Pump Mount
    Old 07-11-2013, 03:14 AM   #29
    My Year: 1985
    Send stlawerance:
    Will do, Thanks again. How do you get this info, its great stuff.
    Old 07-11-2013, 03:32 AM   #30
    Mercruiserparts.com , ebay.com , many others , and way to many boats in my 50 yrs............according to the wifie
    Gas Tank Capacity steve Original Mariah Talk 14 08-05-2024 12:30 PM
    fuel tank capacity jchemotti Mercury MerCruiser 9 07-04-2008 05:41 AM
    Fuel tank and range P&W_43yrs Original Mariah Talk 7 05-02-2008 07:30 PM
    Should a z272 have a water tank? bblauvelt Original Mariah Talk 3 03-11-2008 09:38 PM
    Where's my fuel tank? hey C Original Mariah Talk 9 01-23-2008 12:20 AM
    There are 235 users
