Fuel tank and range
Old 04-22-2008, 09:32 AM   #1
P&W_43yrs is currently offline
My Model: 1995 180 Talari 3.0LX Alpha
Send P&W_43yrs:
Default Fuel tank and range
Can anybody tell me what size fuel tank was used in the original 1995 Mariah, Talari 180? Also, what approximate range can I expect using the 4 Cyl 3.0 LX engine?
Thanks for your time and effort!
  • Old 04-22-2008, 01:56 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Most Mariahs have easy access to the fuel tank. Under the back seat there is a hinged cutout in the floor, flip it up and you have access to the fuel tank. It will have a sticker on it stating it's capacity.
    Range will depend on fast you drive it...
    My Mariah
    Old 04-22-2008, 07:45 PM   #3
    Hi P&W_43yrs,
    You Talari has a 30 gallon tank, I had a similar sized boat (18.5') with the same motor and we were able to play all weekend long ( Water skiing and tubing) and when we were running around, it was pretty much at full throttle and all this on one tank.
    Since fuel gauges are average at best, I recommend the 1/3 rule, 1/3 of a tank out. 1/3 back, 1/3 reserve until you get to know your fuel consumption and you'll never have a out of gas situation.
    Old 04-22-2008, 08:45 PM   #4
    Hi P&W
    Actually your range on that motor should be quite good. Hopefully 180Diablo will chime in here since he has that same combo and is always bragging about how much less expensive it is to run his boat compared to most of the rest of us
    Old 04-23-2008, 01:23 PM   #5
    180diablo's Avatar
    My Model: 1993 Diablo 180
    Gallery Images: 30
    Send 180diablo:
    You rang ... ?
    Range ... hmmm good question. I have never actually filled up the full 20gal (75L) worth tank and measured what I get for a range. I know I was taught how to do that in CPS (Canadian Power Sail Squadron), but I don't remember that already. I should pull out the books again and review so I can figure out my fuel consumption.
    I do know that 30L (7.9gal) will last me a weekend. Basically my weekend would consist of a few hours in the afternoon Saturday and possibly a few hours in the morning Sunday. I do know I went a full 6hour trip (minus 1hr for lunch) on 30L worth of fuel. Which should be in the "Sparrow Lake to Big Chute thread" in the Trips section on here.
    Wetwilly is 100% on the ball with the 1/3rd rule.
    I know this spring I will be installing the resistor onto the back of the fuel gauge in my boat. No more bouncy fuel guage for me!
    Click me here
    ~ Ryan
    Owner of the 3.0L Powerhouse!
    Old 05-01-2008, 01:26 PM   #6
    Send P&W_43yrs:
    Thanks to all of you for your replies! Sorry for the late response; this was the first opportunity I had to review my email.
    When my fuel gauge indicated 1/3 full, filling the tank required only 10 gals. Apparently, the gauge is very non-linear. In a previous response somebody indicated how to get at the fuel tank by removing the engine cover and a couple screws, then folding a piece of the floor back. I did that and the placard on the tank stated it was a 30 gal tank. As for the "range" issue: your responses were very helpful.
    THANKS again!
    Old 05-02-2008, 02:19 AM   #7
    KSP181's Avatar
    KSP181 is currently offline
    My Model: 1994 Barchetta 182, 4.3L alpha 1
    Send KSP181:
    The best thing to due is fill it up, drive it the way you would on an average weekend with a GPS then fill it up again. That will give you a good indication of how much fuel you will burn for the miles. My 4.3L will get as good as 5 mpg at 3200 rpms with the wife and kids aboard (no tubing or skiing). You should have similar results.
    1994 Barchetta 182 - 4.3L
    Vic
    Old 05-02-2008, 07:30 PM   #8
    180diablo's Avatar
    Gallery Images: 30
    Send 180diablo:
    THANKS again!
    I was in the same situation as you were. I was under the impression that 30L (8gal) was filling the tank as well. But that didn't seem right at all, which is why I wanted to pull up the carpet as well and take a look.
    Now I wonder if the marina where I bought the boat from, was only giving me 30L of fuel as a "full tank", when it was barely even half. lol.
    I will be purchasing a second 25L gas can before the season starts and will fill that up as well.
    ~ Ryan
    Gas Tank Capacity steve Original Mariah Talk 14 08-05-2024 12:30 PM
    $1.40 /L for fuel this summer??! 180diablo Chit Chat/Off-Topic 19 04-25-2008 07:54 AM
    Should a z272 have a water tank? bblauvelt Original Mariah Talk 3 03-11-2008 09:38 PM
    Where's my fuel tank? hey C Original Mariah Talk 9 01-23-2008 12:20 AM
    Fuel spills 97 Z222 Original Mariah Talk 1 10-24-2007 08:09 AM
    There are 354 users
