Above Water Exhaust
Old 09-12-2008, 10:12 PM   #1
KCGator is currently offline
My Model: 1996 Z240 Talari 5.7L
Send KCGator:
Default Above Water Exhaust
Can someone tell me the location of the above water exhaust on a 1996 Z240 Talari..I am wanting to put above water exhaust on the boat.
Thanks in advance.
  • Old 09-13-2008, 12:46 AM   #2
    Hi KCGator,
    Here's where they typically install the "Thru-Hull' exhaust on the 96 Talaris (the red circle area), of course it helps if you don't have trim tabs.... Now some have installed the exhaust at the ends of the swim platform (yellow circle area) but this will require a custom exhaust flange so it lays flat on the stepped area.
    Just remember, if you install them in the red area, make sure the exhaust outlets have water flaps installed. With a 454Ci motor and 1/2 full tank, the warter line is just above the top of the transom mount while at rest. that means if you're criusing aroung and shut down quickly, it very possible that water's going to wash right into the outlets.
    If you have the room, some systems now exit out the sides in the rear like NASCAR exhaust:
    Good luck,
    Old 09-13-2008, 11:05 PM   #3
    Send KCGator:
    Default above water exhaust
    Thank you Wetwilly that answered my question
    Old 06-02-2009, 11:55 AM   #4
    gjaxon is currently offline
    My Model: 2001 202 Shabah 5.0L B
    Send gjaxon:
    Default Re: Above Water Exhaust
    You'll love the exhaust system. We have it on our 2001 Shabah. Awesome sound.
    Captains call exhaust---- Z210Shabah Original Mariah Talk 17 02-12-2013 08:32 PM
    THRU HULL EXHAUST for a 218 Shabah JENZO Original Mariah Talk 13 09-19-2009 03:27 PM
    Optional Sound Choice Exhaust ROBERT Original Mariah Talk 5 08-08-2008 05:07 AM
    how much water do you take on? bpfirrman General Maintenance 7 04-29-2008 09:35 PM
    Black Exhaust Marks dudders General Maintenance 15 12-10-2007 03:58 AM
    There are 287 users
