Optional Sound Choice Exhaust
Old 08-07-2008, 06:32 PM   #1
ROBERT is currently offline
My Model: 2001 Z212 78 HRS. LIMITED PHOENIX YELLOW WITH INDY GRAPHICS
Gallery Images: 13
Send ROBERT:
Default Optional Sound Choice Exhaust
I Have A 01 Z212 With 5.7 Merc. And Like The Look And Sound Of The Optional Exhaust.i Know I Know It Will Not Help Power.but It Adds Style.:d Can I Find The Stock System For My Boat With The Stock Tips.
  • Old 08-07-2008, 07:20 PM   #2
    Send bpfirrman:
    THRU HULL EXHAUST for a 218 Shabah
    Here is a link to a previous thread that discusses it. Will be pretty pricey!
    Old 08-07-2008, 07:38 PM   #3
    You can certainly add the system now, however it is expensive, and you will not be able to find the stock tips, as they were made in-house at Mariah before they closed in 2001.
    Click the thread above for a more in-depth discussion.
    Old 08-07-2008, 08:04 PM   #4
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Chris - actually, Corsa does/did make the tips. Follow that thread, then follow the thread I referred to, then see my post that has the Corsa line drawings and part numbers.
    Or, just click here and go to the last post.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 08-07-2008, 08:35 PM   #5
    I stand corrected! Thanks for pointing that out Ryan. I knew they used the Corsa system, but was unaware they made the tips as well. Good find!!
    Old 08-08-2008, 05:07 AM   #6
    95 z200 is currently offline
    Send 95 z200:
    you might check ebay you can find them on there cheap sometimes, probably not going to be original. just a thought
    1995 talari z200
    Captains call exhaust---- Z210Shabah Original Mariah Talk 17 02-12-2013 08:32 PM
    THRU HULL EXHAUST for a 218 Shabah JENZO Original Mariah Talk 13 09-19-2009 03:27 PM
    Silent Choice Player311 Sea Fox - Mariah Talk 9 06-24-2009 04:31 AM
    Black Exhaust Marks dudders General Maintenance 15 12-10-2007 03:58 AM
    prop choice Acadianbasic Prop Talk 3 08-27-2007 12:18 AM
    There are 250 users
