Talari z235 (1996)
Old 08-04-2007, 02:42 PM   #1
ChicagoWeb is currently offline
Send ChicagoWeb:
Default Talari z235 (1996)
Hello,
I was wondering if anyone with this same model can send me the following information:
In the cuddy cabin there is a bar that goes across the benches so that you can turn the cuddy into a bed. The problem is I don't have the bar... I am looking for the dimensions of the bar, material it is made out of, etc...
I have the holders for the "bar" just missing that part.
Thanks!
___________________
ChicagoWeb
1996 - Talari z235
23.5ft w/cuddy cabin
Prestige Custom Trailer
Lake Freeman, IN
Lake Michigan, IL
  • Old 08-19-2007, 10:15 PM   #2
    Send ChicagoWeb:
    bump... anyone? I know their are others with talaris!
    ___________________
    ChicagoWeb
    1996 - Talari z235
    Lake Freeman, IN
    Lake Michigan, IL
    Old 08-20-2007, 07:44 PM   #3
    215Talari is currently offline
    Send 215Talari:
    No bar in mine, but couldn't you "make" one with materials from Northern Tool or Home Depot?
    1996 Mariah 215 Talari
    Ron Hill Marine Go Fast Parts
    Minneapolis, MN
    Old 08-20-2007, 11:11 PM   #4
    Send ChicagoWeb:
    Yes, I can make it but I need to know the dimensions etc... I never had the bar, bought the boat used.
    Anyone else?
    ___________________
    ChicagoWeb
    1996 - Talari z235
    Lake Freeman, IN
    Lake Michigan, IL
    Old 08-21-2007, 01:52 AM   #5
    Send 215Talari:
    sorry I couldn't help you. Apparently the 215 Talari is setup differently. So you're saying that there are bars that go across the footwell area so the cushion sits on top of it? Do you have any pictures?
    Minneapolis, MN
    Old 08-21-2007, 02:14 AM   #6
    moondance100's Avatar
    moondance100 is currently offline
    My Model: 1995 Z240 Talari 502 Bravo III
    Send moondance100:
    I don't know if it helps any, but my bowrider has square pieces of plastic that run along the footwell of the bow, just below the cushoins. It's rectangular with the narrow side horizontal and the wide side vertical. I'm not around my boat right now, but i would guess the dimensions to be around .75"x 1.5"....again, they run along the footwell instead of across it.
    Good luck!
    Doug
    95 Z240 Talari, 502, Bravo 3
    Old 09-09-2007, 09:46 PM   #7
    aaron999888's Avatar
    aaron999888 is currently offline
    My Model: 244 Jubilee
    My Engine: 7.4L Penta DuoProp
    Gallery Images: 38
    Send aaron999888:
    I just picked up my '96 235 Talari the other day and have now read your post. I have that bracket in mine and have measured it.
    It is a piece of angeled aluminum that is 36" long. One side of the angle is 1 1/2 " and the other side is 1".
    Hope this helps.
    Old 09-09-2007, 09:49 PM   #8
    Gallery Images: 38
    Send aaron999888:
    As an additional thought. If the former owner hadn't shown me where mine was located I would have been in your same position.
    If you haven't already, check the little apholstered ridge above the windows to see if maybe your bracket is hiding there.
    Old 09-11-2007, 04:25 PM   #9
    Send ChicagoWeb:
    Is there anyway you can send me a picture?! This is huge, thanks so much.
    [email protected] is my e-mail
    ___________________
    ChicagoWeb
    1996 - Talari z235
    Lake Freeman, IN
    Lake Michigan, IL
    Old 09-12-2007, 03:20 AM   #10
    Gallery Images: 38
    Send aaron999888:
    Here is a photo of the angled aluminum bar. I assume this would be fairly common stock material at Home Depot, or any metal supply.
    Hope this is helpful.
    Aaron
    1996 Z 240 Talari WetWilly Introductions 9 11-17-2007 05:52 AM
    1996 Talari 235 Cuddy aaron999888 Introductions 24 09-13-2007 05:04 AM
    Just bought a 1996, Talari 235 ChicagoWeb Original Mariah Talk 3 09-07-2007 04:47 PM
    New owner of a Talari 209 1996 christian Introductions 3 07-31-2007 05:22 PM
    There are 317 users
