Got to have lights!!!!!!!!!!!!!!!
Old 07-14-2009, 10:40 AM   #21
Default Re: Got to have lights!!!!!!!!!!!!!!!
Jeff B.[/QUOTE]
Hi Jeff, looks like something the previous owner did. You couldn't install the switch if the knobs were glued on (knob too big to fit through the hole ).
  • Old 07-14-2009, 10:41 AM   #22
    Originally Posted by jkb944t View Post
    I would have gone this route but my switch knobs are all glued on and I was afraid that I would break the switch getting it out. I am not sure if they are always glued on or if this is something a previous owner did.
    Jeff B.
    Jeff B.[/QUOTE]
    Hi Jeff, looks like something the previous owner did. You couldn't install the switch if the knobs were glued on (knob too big to fit through the holes ).
    Old 07-14-2009, 11:32 AM   #23
    jkb944t is currently offline
    Send jkb944t:
    It stands to reason that the factory could have glued the knobs on after the switches were installed.
    Jeff B.
    Old 07-14-2009, 11:54 AM   #24
    True, but then you'll have your situation, can't remove the switch because the knobs are too big to fit through the holes
    Old 07-14-2009, 12:02 PM   #25
    Send jkb944t:
    Good way for the factory to sell more switches. Wouldn’t be the first time an OEM made it difficult to service a part.
    I would gather from what you are saying though, that on other Mariah boats the factory didn’t typically glue on the switch knobs so it must have been a previous owner.
    Jeff B.
    Old 07-14-2009, 01:11 PM   #26
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Not the way Mariah did things, near as I can tell.
    Jim
    Old 07-19-2009, 09:29 AM   #27
    Jeff B.
    Hi Jeff,
    As SEMIJim said, "it's not the way Mariah did things..."
    So I would say it was someone else...
    Old 07-19-2009, 12:13 PM   #28
    grommett's Avatar
    grommett is currently offline
    My Model: Z202 Shabah
    My Engine: 350 Magnum 5.7L Alpha
    Gallery Images: 10
    Send grommett:
    Are you sure they are glued on, mine were very tight and I had to lever them off with a screwdriver (very carefully)
    Old 07-20-2009, 01:23 PM   #29
    midwest mariah's Avatar
    midwest mariah is currently offline
    My Model: 1996 MX180 Shabah 3.0L Alpha 1
    Send midwest mariah:
    same here, a very careful push, tug and pull, and they popped off, no glue!
    Dash Gauge Lights Out Roger Butterfield General Maintenance 20 01-12-2009 08:38 PM
    dock lights ?? MinnetonkaMariah Original Mariah Talk 4 07-17-2008 11:33 AM
    Courtesy lights out waynehooper General Maintenance 1 07-15-2008 06:36 PM
    Courtesy Lights plokhoyc Sea Fox - Mariah Talk 7 07-15-2008 02:49 AM
    dash lights John Miller Original Mariah Talk 3 05-20-2008 02:08 AM
    There are 234 users
