93' Diablo 180 outboard engine 150 HP porpoising
Old 06-28-2023, 06:39 AM   #1
NikFil's Avatar
NikFil is currently offline
My Model: 180
My Engine: 150 Mercury EFI
Send NikFil:
Default 93' Diablo 180 outboard engine 150 HP porpoising
Hi All,
I've recently entered into the world of speed boating with a Diablo 180. Overall it is a great handling boat, even took it out on a 4 scale Beaufort and it handled the waves well.
I'm having a bit of an issue with the fuel consumption its close to 2 liters per nautical mile probably due to allot of porposing at cruising speed of 25-30 knots at 3000 rpm and that forces me to trim the engine down almost to the 3/4 to all the way depending on the chop of the open sea (reduces my consumption a bit and stops porpoising). Also noticed that that it will max out at 4000rpm and I'm thinking of trying a different propeller maybe a high five to see if the extra blades help the engine open up more.
  • Old 07-07-2023, 03:51 PM   #2
    GregT is currently offline
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Default Re: 93' Diablo 180 outboard engine 150 HP porpoising
    I'm not overly familiar with your boat, but have you considered installing smart-tabs to help level it out?
    Old 07-10-2023, 06:26 AM   #3
    NikFil's Avatar
    My Model: 180
    Send NikFil:
    Hi GregT,
    Probably will install tabs , just doing some research but will probably go for the hydraulic or air system ones.
    Now im thinking of swapping 3 blade 21p with a five blade 21p to see if I can plane better without having to down all the way the engine.
    Old 07-12-2023, 01:43 AM   #4
    You dont need hydraulic or electric trim tabs on a 180. Just install a pair of Nauticus Smart Tabs with the 60# arms and they will do the job. A 3 blade 21" pitch prop is a 'cruising' prop for those boats. A 5 blade will help but dropping to a 4 blade 19" pitch and a pair of Smart Tabs will have your boat jumping out of the hole and also improve your mid range acceleration at the cost of about 2 mph top speed. That's a good trade-off in my books.
    GregT likes this.
    porpoising real bad need help Shawn s Original Mariah Talk 21 08-06-2017 09:43 PM
    Top Speed Diablo with 90hp Mariner Outboard phdeds Original Mariah Talk 3 08-01-2017 03:00 PM
    porpoising z210 jsewall82 Original Mariah Talk 33 06-08-2013 02:34 PM
    1992 mx18 diablo engine questions please help 420-420 Mercury MerCruiser 3 12-09-2012 07:16 PM
    There are 303 users
