Late shift into forward
Old 09-29-2021, 12:33 AM   #1
wejaz28's Avatar
wejaz28 is currently offline
My Model: 200 Shabah
My Engine: 350 Mercruiser
Send wejaz28:
Default Late shift into forward
My outdrive shifts into forward at just before the throttle begins to come in.
How do I make it shift into gear a little sooner so it doesn't take off as soon as it goes into gear?
5.7l- Bravo 1
  • Old 09-29-2021, 02:00 PM   #2
    Default Re: Late shift into forward
    Bravo Shift Cable Adjustment : MerCstuff.Com
    Old 09-29-2021, 03:11 PM   #3
    wejaz28's Avatar
    Send wejaz28:
    So if the the cables are within spec, Is there a throttle adjustment to come in later?
    Old 09-30-2021, 01:59 AM   #4
    I'd say do the cable adjustment first. They stretch over time. Here's another pic
    Old 10-05-2021, 07:12 PM   #5
    wejaz28's Avatar
    Send wejaz28:
    Using the picture of the cable's adjustment, I was able to get the results I was looking for.
    Again Mikeyt, thanks for your help....
    mikeyt likes this.
    Old 10-07-2021, 02:06 PM   #6
    wejaz28's Avatar
    Send wejaz28:
    Does the shift interrupt circuit get out of adjustment when you adjust the shift cables?
    Can i fit a sub in rear bench facing forward? Bdbwtie Original Mariah Talk 13 08-03-2016 10:11 PM
    Dashes for late model Mariahs ConVICK_Pitbull Sea Fox - Mariah Talk 2 11-02-2012 03:46 PM
    forward in reverse karae225 Mercury MerCruiser 4 06-15-2010 10:21 PM
    Control arm not shifting out of forward Lunaticutah Original Mariah Talk 3 06-26-2009 04:14 PM
    befor its to late lawmanbsi Original Mariah Talk 2 11-06-2008 11:02 PM
    There are 370 users
