Nav Lights not working
Old 04-07-2019, 06:17 PM   #1
siudog is currently offline
My Model: MX19
My Engine: 4.3LX
Send siudog:
Default Nav Lights not working
Ironically, there are recent posts regarding this, and good replies related to switch corrosion, however my 1993 MX19 is showing other weird symptoms. I am good with electrical, so please don't bother with the basics... Neither nav or anchor works, front or back. Front & rear lights works in my other boat. Initially I thought it was the battery even though it is such a small load, because if I put the charger on for a few hours they would work OR while driving, once on plane for awhile and charging up, they would work. Tried 3 other batteries out of my other boats this year and now they don't work at all. Sounds like a switch or ground, but my switch is at the top of the vertical panel of switches and cannot be accessed no matter what. what a hokey design. There is no way I can get at the switch or remove the bank of switches from the dash. any ideas? maybe I'm missing something. I jumpered in a new ground wire no effect. I have the wiring diagram, no juice at the light sockets. Before I rig up a new switch, I thought Id as about switch access, hope you guys can help.
  • Old 04-07-2019, 11:36 PM   #2
    Default Re: Nav Lights not working
    Like it or not, i'm going to remind you of the 'basics'. Check and clean the positive and ground wires at the battery and the connections at the distribution bars. Should be one on the inside of the transom near the battery and another up under the dash. There isn't much else that can go wrong.
    Z255 Shabah NAV Lights Not Working SeattleRemedy Original Mariah Talk 2 03-11-2019 09:58 PM
    Courtesy lights not working rosco0000 Introductions 6 10-25-2017 12:28 AM
    nav lights and gauge lights not working lumbercitybravest Original Mariah Talk 5 08-13-2013 05:11 PM
    Navagation lights not working Mariah on the bay Original Mariah Talk 1 06-12-2012 10:13 AM
    Cabin Lights not working Daxgirl Original Mariah Talk 1 04-28-2009 04:07 AM
    There are 358 users
