Courtesy lights not working
Introductions
Old 09-25-2017, 03:06 AM   #1
rosco0000 is currently offline
My Model: 214 Jubilee
My Engine: 5.7 chevy
Send rosco0000:
Default Courtesy lights not working
Anybody out there have problems with courtesy lights? I've replaced all the bulbs. I have a 2000 Jubilee 214. Thanks in advance!
  • Old 09-25-2017, 05:24 AM   #2
    Tinman2809 is currently offline
    My Model: Barchetta
    My Engine: 4.3 Yamaha stern
    Send Tinman2809:
    Default Re: Courtesy lights not working
    Mine don't work either on my barchetta....did u check the fuse?
    Old 09-26-2017, 12:46 AM   #3
    Send rosco0000:
    Yes checked all fuses
    Old 09-26-2017, 06:48 AM   #4
    porker is currently offline
    My Model: 209 Talari
    My Engine: Volvo Penta 7.4L/SX
    Send porker:
    If fuses are good I would bet on a bad connection somewhere, which are never fun to hunt down. I would suggest tracing it from wherever you can access the circuit and testing for voltage or continuity until you find the issue. Don't forget to test for a bad ground, too.
    My new to me Mariah had a couple of circuits that weren't working consistently and they were resolved this summer when I replaced the fuse block and all fuses.
    Old 09-26-2017, 11:55 PM   #5
    pole trick is currently offline
    My Model: 180 Shabah
    My Engine: 4.3 Merc
    Send pole trick:
    The fuse maybe good but is the fuse block good and tight on both ends of the fuse. My 96 180 has
    The most cheepest fuse block I ever seen. The fingers that hold the fuse where spread out
    And only touching on one end of the glass fuses on some of them
    Old 10-04-2017, 04:19 PM   #6
    John822179 is currently offline
    My Model: Z225 Davanti
    My Engine: 5L FL V8
    Send John822179:
    Are they oval lights or square swivel lights?
    John822179
    Mariah Z225 5L V8
    Keep the dry side up
    Old 10-25-2017, 12:28 AM   #7
    printing1910 is currently offline
    My Model: Z242
    My Engine: 7.4 MPI bravo three
    Send printing1910:
    Its a time consuming process, but here are a few suggestions for you to try. Check to see if the switch is working properly. Using a test meter, turn the switch on and off and see if you get 12 volts. I believe that these lights are wired in series. disconnect the wires from one light at a time, make two jumper wires from the battery and wire directly to light to see if the light does work. If it does then work your way from each light back to the switch. Hope this helps you!
    Replacement Courtesy Lights WetWilly Original Mariah Talk 27 05-24-2020 07:24 PM
    MX19 Docking and Courtesy Lights foolmoo Original Mariah Talk 3 08-12-2013 08:22 PM
    Courtesy lights out waynehooper General Maintenance 1 07-15-2008 06:36 PM
    Courtesy Lights plokhoyc Sea Fox - Mariah Talk 7 07-15-2008 02:49 AM
    Wanted: Interior Courtesy Lights? bdbyrnes Mariah Parts For Sale & Wanted 2 10-17-2007 09:48 PM
    There are 226 users
