1997 Shabah Z222 - Twitching fuel gauge
Old 09-26-2018, 02:31 AM   #1
Likwid13's Avatar
Likwid13 is currently offline
My Model: Z222 Shabah
My Engine: 7.4L dualprop
Send Likwid13:
Default 1997 Shabah Z222 - Twitching fuel gauge
Hi everyone. I recently bought a 1997 Mariah Shabah Z222. The fuel gauge sometimes bounces around quite a bit,making it nearly impossible to tell the correct fuel level. I have seen many posts about this issue related to the fuel sender. I flipped the back seat completely forward to look for a little hatch to access the sender, but I could see nothing. Does anyone else have a similar boat to show me a picture of where this mystery hatch might be. Any help would be great, as the boat is currently at the shop and the mechanic is telling me we either need to tear up the whole floor, or live with it as is. Thanks s
  • Old 09-27-2018, 12:10 AM   #2
    Default Re: 1997 Shabah Z222 - Twitching fuel gauge
    You've got a mechanic that's trying to scare the sh!t out of you and is too dammed lazy to figure it out. Just follow the fuel filler line down and it will lead you right to the point where the hatch is located. Twitching fuel gauge needles seem to be a regular issue with Mariahs. There is a thread here somewhere (from a few years back) where one of our electronically knowledgeable members explained how to fix the issue once and for all with a couple of resistors. I've attached a copy of his instructions that i downloaded way back when.
    Old 09-29-2018, 02:12 AM   #3
    Likwid13's Avatar
    Send Likwid13:
    What do these little hatches look like? Are they just a cutout in the carpet? Or are they an actual plastic hatch of some kind. Any advice would be helpful. Thanks
    Old 09-29-2018, 02:50 AM   #4
    Mine is just a small cut-out in the carpet right where the floor meets the bilge area.
    Old 09-29-2018, 10:39 PM   #5
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    Mine is under the center of the rear seat on a 202. The cover is cut out but the carpet was not. Apparently it had never been accessed since 1999. You should be able to feel the cover edge under the carpet. But I was not able to remove the cover and had to just unscrew and tilt up the whole center of the seat.
    1998 242 Shabah -Fuel gauge dthompson43 Original Mariah Talk 7 05-31-2018 10:24 PM
    1997 Z222 limited Rhurd7799 Original Mariah Talk 0 02-25-2017 06:26 PM
    1997 Mariah Z222 Shabah for sale--Worth it? Rallysport91 Mariah Boats For Sale & Wanted 13 03-17-2014 03:27 PM
    Fuel capacity on a 97 Z222 Shabah? Eclipse9719 Original Mariah Talk 3 06-09-2013 01:44 PM
    There are 277 users
