1998 242 Shabah -Fuel gauge
Old 05-29-2018, 05:37 PM   #1
dthompson43 is currently offline
My Model: 242 Shabah
My Engine: 7.4L
Send dthompson43:
Post 1998 242 Shabah -Fuel gauge
Newbie boater here and just went through our first summer holiday. We started the weekend and the fuel gauge seemed to be working. We took it to the marina to get filled up. They filled it all the way and when we started the engine back the fuel gauge showed on empty. It never changed the rest of that day. Needle did not seem to move. The next day we started engine and the needle moved to full. We were so excited and then all of a sudden it dropped back to empty. The rest of that trip the needle would move but mainly stayed on empty but I know we have a full tank of gas. Any thoughts on what caused this and how to fix it? Please keep in mind we know nothing about boats however my husband is very mechanical over all just not on boats yet.
  • Old 05-30-2018, 02:27 AM   #2
    Default Re: 1998 242 Shabah -Fuel gauge
    Likely a short or bad connection at the fuel sender unit located in the floor just in front of the engine.
    Old 05-30-2018, 10:12 AM   #3
    My Engine: 7.4L
    Send dthompson43:
    Is this hard to locate and repair? We are hesitant about having to actually get in the fuel tank. Any details on fixing this would be great. I hate to pay for a mechanic if not necessary.
    Old 05-31-2018, 03:13 AM   #4
    Not really difficult at all. The fuel sender connection sits just below a small flap in the floor just in front of the engine. You are not going to do anything inside the fuel tank, just to the connections that are mounted on top of it.
    dthompson43 likes this.
    dthompson43 (05-31-2018)
    Old 05-31-2018, 11:57 AM   #5
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    You will be specially looking for a loose or broken connection to either the wire going to the center bolt on the fuel sender or to the ground wire which is typically attached to one of the bolts on the flange. I say loose or broken wires as your symptoms, showing empty when actually full indicate as such. You should also check that there is no corrosion on these two connections. An open circuit manifests as an empty indication while a short circuit of these two wires manifests as a full indication.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-31-2018, 03:38 PM   #6
    My Engine: 7.4L
    Send dthompson43:
    This sounds encouraging it is nothing big. Since we are so new to this if you have a way to send a pic to what we need to be looking for when trying to find the sending unit that would be so helpful. My husband is very mechanical but I think the boat has him a little hesitant since it is all so new to us.
    Old 05-31-2018, 10:13 PM   #7
    Here are a couple of generic photos of a fuel sender unit. Steve has it right regarding what you should be looking for. It's not difficult but if it makes you feel safer, then disconnect the battery terminals before you work on the sender unit.
    Old 05-31-2018, 10:24 PM   #8
    My Engine: 7.4L
    Send dthompson43:
    We will give it a try. Thank you all for your help. I am so thankful for this group and the support everyone gives
    Fuel Gauge not working. 1996 Mariah Z252 General Maintenance 1 07-12-2017 04:36 AM
    Gauge Replacement in a 1998 202 pllevine General Maintenance 3 09-12-2015 06:56 AM
    fuel gauge not working right Hoseman Original Mariah Talk 1 05-18-2010 02:32 AM
    Fuel gauge not working kingtide Original Mariah Talk 5 07-26-2008 06:34 PM
    There are 265 users
