Depth finder
Old 06-20-2018, 08:37 PM   #1
Jack L. is currently offline
Send Jack L.:
Default Depth finder
1994 Shabah Z212 the depth finder is not working? any thoughts?
  • Old 06-21-2018, 11:42 PM   #2
    shortedout96 is currently offline
    Send shortedout96:
    Default Re: Depth finder
    Not working at all or unrealistic depths. My factory one has correct depths every once and awhile but most of the time it is way off.
    Old 06-22-2018, 02:04 AM   #3
    If its mounted in the bilge area and is a thru hull unit, its likely that it has come loose in the epoxy mount (age/wear & tear) and wont read at all.
    Old 06-22-2018, 02:13 AM   #4
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    What make is the head unit? My boat's original Lowrance unit was defective when I bought the boat a year ago. it turned out to be a defective transducer. A new transducer (shoot-thru-hull epoxy glued into hull) fixed it. But I got greedy and tried to fix the lights inside and ruined it, very delicate connections at that age.
    You can test the transducer to see if it has gone open-circuit by putting a small AM radio near it while the depth finder is switched on. The radio should make an easily heard clicking sound if ok. Best frequency to use is 550-600 KHz. If the head unit is working but the transducer is open, the clicking will be very faint.
    Old 06-22-2018, 10:57 AM   #5
    Send shortedout96:
    Where was your transducer located?
    Old 06-22-2018, 01:49 PM   #6
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    It was under the engine. There was a cutout in the inner hull to allow it to be glued to the outer hull.
    Old 06-23-2018, 02:02 PM   #7
    Send Jack L.:
    Thanks for all the replys. i will will try your suggestions and thoughts.
    thanks
    Depth Finder diablo18 Original Mariah Talk 14 05-28-2013 02:15 PM
    Depth finder gauge Jaztwnz General Maintenance 11 05-15-2013 06:39 PM
    Depth Finder issues gly101 General Maintenance 1 06-10-2012 02:57 AM
    Depth Finder jchestnutt Introductions 1 05-06-2012 12:16 AM
    Depth finder joeboat Original Mariah Talk 1 08-21-2009 12:54 AM
    There are 281 users
