1998 Jubilee Tachometer
Old 09-17-2017, 05:15 PM   #1
Jubilee is currently offline
Send Jubilee:
Default 1998 Jubilee Tachometer
I am looking for a wiring schematic for the instrument panel for my 98' Jubilee. I recently converted from the 2 barrel Holly to a TBI, and in the process I lost the function of the tach. I am assuming the the tach ran off of the distributor and or computer, both of which were replaced, and their respective wiring abandoned. I would like to figure out how to integrate the factory Tach into the new ignition but I first need to figure out how it worked with the old system. Any help is appreciated.
  • Old 09-17-2017, 11:38 PM   #2
    tbrookens's Avatar
    tbrookens is currently offline
    My Model: Shabah Z252
    My Engine: 454 Mag, Bravo 3
    Gallery Images: 2
    Send tbrookens:
    Default Re: 1998 Jubilee Tachometer
    How hard was the conversion?
    Tracy Brookens
    Old 09-17-2017, 11:58 PM   #3
    Send Jubilee:
    Not bad really. I put about 35-40 hours into it. The kit comes with just about everything you'll need. I had to buy some misc. fittings and some fuel line, and I had to fab up some brackets and linkage parts, but that's really it. If I had to do it again I could probably do it in 25-30 hours. As long as you're mechanically inclined, and not scared, it's a pretty smooth operation.
    Do you have any insights into the tach issue?
    Old 09-18-2017, 02:10 AM   #4
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    I am pretty sure the tach signal will come from the coil. Should be a gray wire at one of the two terminal A's. What ECU model do you have, MEFI 1, 2, 3, 4, or 5? Did you get a different coil with the kit?
    Old 09-18-2017, 02:26 PM   #5
    My Model: 180 Diablo
    My Engine: 3.0 Mercruiser
    Send TN_Diablo:
    First my boat is a 2001 carbureted and may have same /similar Fariah tach but not sure. If it is the same I'm pretty sure they do get signal from the (-) side of the coil and it probably had breaker-less (no points) ignition but still a distributor. Fariah website may give you some technical details.
    If you no longer have a distributor and have coil packs now fired by new computer you may have a problem. There is a switch on the back of those Fariah tachs that lets you select 4, 6, 8 or 12 cylinders (IIRC) but not a single cylinder engine as you might need to do with coil packs. Does your new set up still have a distributor? If not maybe the new computer has an output provision for a tach if you dig into their technical details. I would think it should.
    I've had trouble with my tach and had it out and apart to free it up from sticking. When I had it out last I tested it on an older (80's) 6 cylinder BMW ignition on the coil (-) and set to 6 cylinder and it worked and read accurately. Switched it back for the boat, reinstalled, and it has worked great.
    Member Boat For Sale: 1998 240 Jubilee RMBIGDOG Mariah Boats For Sale & Wanted 0 04-05-2017 04:03 PM
    Member Boat For Sale: 1998 21' Mariah Jubilee ftmyersmariah Mariah Boats For Sale & Wanted 0 05-19-2016 08:47 PM
    1998 Jubilee 214 Blenderbill Original Mariah Talk 9 05-16-2013 10:30 PM
    Wanted: 1998 204 Jubilee bigdoggone Mariah Parts For Sale & Wanted 5 07-07-2009 01:42 AM
    Jubilee 214 1998 rulin5150 Introductions 4 10-11-2008 10:53 PM
    There are 375 users
