ECU scan software for free
Old 08-18-2017, 02:19 AM   #1
GaryDoug's Avatar
GaryDoug is currently offline
My Model: Z202
My Engine: 5.7L Bravo III
Send GaryDoug:
Default ECU scan software for free
As I mentioned a few months ago, I bought an ECU scanner program for pc from OBDDiagnostics called MEFIscan3/ScannerPro. I am not very happy with the performance of the package and have started writing my own software. I am experienced with this and have done some applications before for cars. This application will be almost identical to ones I have done before, so no surprises here. It make take a few weeks or months to get it done to a good usable level. But if anyone is interested, I will be giving it away for free via a download, as I have done for previous automotive programs. The cable that came with the kit can be duplicated for $20 for a basic cable and about $10 for the 10-pin connector required for the boat. You would just have to solder it to the cable. The use of a Windows PC nearby, preferably a laptop or notebook, would be required also.
Let me know if anyone is interested in using it. This would only work for the MEFI-3 ECU modules. The part numbers on the MEFI-3 ECU, as far as I know, would be 16236999, 12489488, or 12489493.
There will be no advertising, nag screens, or any strings attached with the use of this software. If you want to see what I have done before, just do an internet search for Scan9495.
  • Old 08-20-2017, 02:27 AM   #2
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Default Re: ECU scan software for free
    Well, if nobody wants a copy, then I will take my time with it.
    Old 08-20-2017, 02:14 PM   #3
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Gary,
    I would be real interested in your software but unfortunately I have the MEFI2 on my 7.4MPI engine. It is a very generous offer of your time and talent.
    Steve
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 09-01-2017, 08:59 PM   #4
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    My scan program is ready to use and can be found here: https://www.mediafire.com/folder/57e...f51/MEFI3-Scan
    In the same folder are also instructions in a readme file, some screen shots, a photo of the location of the scanner connection, and for those who would prefer to use something more well-known, there is an adx definition file for use with TunerProRT (also free). The readings on the screen shots may look odd, because the ecu was not connected to anything but a power supply at the time.
    These will only work for the MEFI-3 module. If anyone has a ".adx" definition file for the MEFI-1, MEFI-2, or MEFI-4, I would appreciate a copy of the file.
    Old 05-31-2018, 03:08 AM   #5
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Update:
    In a few days I will have a scan version for the MEFI-4. A kind soul on the Malibu boat web site is beta testing it for me now. It's going very well.
    I also have definitions for the MEFI-1 and MEFI-2. So if someone with either of those wants to do some testing, we can make that a reality also. I noticed Steve seemed to be interested (?).
    I think it's pretty good software even if I say so myself ;-) And the price is good, free.
    mikeyt likes this.
    Old 05-31-2018, 11:49 AM   #6
    My Model: Z280
    Hi Gary,
    I am still interested. Let me know how I can help.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-31-2018, 03:03 PM   #7
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Steve,
    First you will need a Windows Vista, 7, 8 or 10 pc close to the engine; laptop, notebook or tablet are best.
    Second you will need a cable fro the pc to the diagnostic connector on the engine, it is a 10pin 'Opel" connector usually fastened near the ECM. There are no pre-made cables at a reasonable price, so you will have to make one.
    Here are the parts:
    Connector: https://www.mouser.com/ProductDetail/829-12045808
    Pins for connector (2 minimum): https://www.mouser.com/ProductDetail/829-12045773
    Cable: https://www.mouser.com/ProductDetail...DpPMdam%2fwe00
    Cut off 6-pin connector (NOT USB end !) from FTDI cable
    Connect black wire to pin A (ground) of the 10-pin “Opel” connector. I recommend soldering the wires.
    Update: you will need a small diode to add inline to the orange wire, Put the cathode end of the diode toward the end with the USB connector. See a later post for a photo.
    Connect yellow and orange wires to pin G (data) of the 10-pin “Opel” connector
    (These need to be the wires from the TXD and RXD terminals on the USB end. Some cables use white and green instead. You may be able to pry off the cover at the USB end to see them)
    You do not need all the strain relief and water seals for this connector.
    Once you have the cable made, I may be ready with the trial version. You can try it on the engine with the ignition on but engine not running. Later, after the program is farther along, you would need to run it with the engine running. The boat does not have to be in the water. In all cases, I will need you to send me the log file(s). We can communicate via email directly if you prefer.
    This version of my program will be free to use with no annoying nag screens, advertisements or other encumbrances. But the pc you use to get this program must be able to allow downloads of an exe file.
    In the attached diagram, do not connect pins A and B as shown. That is only used to initiate trouble code flashing and cannot be done while scanning normally.
    Gary
    Thank you GaryDoug for this useful post!
    1brent1 (06-07-2018)
    Old 06-05-2018, 03:07 AM   #8
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    MEFI4.exe beta version 013 is available here:
    http://www.mediafire.com/file/b6r9np...MEFI4.exe/file
    Old 06-10-2018, 03:29 AM   #9
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Four downloads and nobody has any feedback about whether it works for you or not?
    Old 07-06-2018, 11:45 AM   #10
    My Model: Z280
    Gary,
    My cable is ready. Have you had a chance to work on the program? Let me know next steps.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    mgrenon (04-03-2020)
    For Sale: Free 2000 z272 ladder lisapaul1 Mariah Parts For Sale & Wanted 2 05-20-2016 05:19 PM
    Free 1995 z220 talari project boat, portsmouth va. buchshot12000 Mariah Boats For Sale & Wanted 3 05-30-2012 03:12 PM
    free teal convertible top for '96 Talari BarkerD Original Mariah Talk 3 08-20-2010 12:11 PM
    1993 Mariah shabah I ended up getting it for free benelli5150 Original Mariah Talk 2 06-27-2010 11:38 AM
    There are 302 users
