ECU scan software for free
Old 07-06-2018, 01:31 PM   #11
GaryDoug's Avatar
GaryDoug is currently offline
My Model: Z202
My Engine: 5.7L Bravo III
Send GaryDoug:
Default Re: ECU scan software for free
Hi Steve,
I will be working on the MEFI2 program this weekend and may have something to test early next week. It will involve collecting a log file while running the program, which will NOT yet work properly for the mefi2. I just need to get the data before plugging in all the info for the mefi2.
In the meantime, you can install the drivers needed for the cable, Your pc should download and install the drivers automatically if it has an internet connection. If it doesn't, let me know,
Gary
  • Old 07-09-2018, 02:57 AM   #12
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Came down with some flu-like symptoms today so this may take a little longer, but it will get done.
    Old 07-09-2018, 10:14 AM   #13
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Feel better. Have to take a business trip this week then away for a week on vacation. Will not be able to get to it until late July.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 07-24-2018, 02:26 PM   #14
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    The MEFI2 scan program is ready to try: http://www.mediafire.com/file/zb1b02...MEFI2.zip/file
    It is an ".exe" file and your pc will probably warn you seriously about trusting it. You can select "run anyway" or something similar depending on the operating system and/or antivirus protection installed..
    I have found that some cables need to have a small low-power silicon diode added to the cable. It goes in the orange (TXD) wire with the anode end toward the ECM connector end. Any small diode will work, I used a 1n4001 type. Without the diode, many cables will not connect.
    Your pc will need to have Microsoft .Net Framework installed, ver 4.0 or later. Most newer pcs already have it installed, but if not, you can download it for free from Microsoft.
    To test the software, the ignition must be on, but the engine does not have to be running yet. After we confirm operation, we can talk about some data collection with the engine running later.
    You will need o determine what virtual serial port (Comx) is used by the cable. To do that, start the program without the cable attached. Note which Com ports, if any, are listed in the program's Com Port drop down selection box. Stop the program and plug the cable into the pc. Then restart the program and note the Com port number that is added to the list. You will select that one in the program. Connect the other end of the cable to the connector on the engine and turn on the ignition switch. Click on Connect and data numbers should appear in the engine tab screen boxes. If not, we can troubleshoot that. If they appear, you can click on Scan and see live data. About the only useful thing that you can see with the engine not running is the throttle position. You can move the throttle and see the changes for that.
    antiainsar likes this.
    Old 11-27-2020, 08:54 PM   #15
    Roger Mija is currently offline
    Send Roger Mija:
    Originally Posted by GaryDoug View Post
    MEFI4.exe beta version 013 is available here:
    http://www.mediafire.com/file/b6r9np...MEFI4.exe/file
    I have downloaded your scanner. Do you think it will work on a Crusader 8.1L MPI MEFI4b?
    I have both OBD and DTC. Which would work best?
    Old 11-27-2020, 11:38 PM   #16
    Send Roger Mija:
    I downloaded the software. Thanks.
    Will this work with Crusader 8.1L, MPI, MEFI4b?
    Do you use the OBDII of DTC connector?
    Old 11-29-2020, 02:32 AM   #17
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    I do not know what version ecm you have. Is it an MEFI4? or 3 or 2?
    If you see a 16-pin OBD2 connector, then it probably will not work. The connector must be a 10-pin version as described above. And you need to make a special cable just for the MEFI ecm's.
    Old 12-06-2020, 03:12 PM   #18
    Send Roger Mija:
    Your software works great on 2004 Crusader 8.1L with MEFI4b. Your software is smoother to set up than the many of the other options. Thank you for your work and offering this as freeware.
    Old 02-18-2022, 02:17 AM   #19
    Originally Posted by biellia View Post
    With this OBD2 diagnostic app, you can communicate with your car's OBD-II system quick and easy, and turn your mobile into a highly capable automotive scanner. ... This app is free but to unlock all the features, an upgrade is available using in-app purchase.
    Since you are a spammer, I assume you haven't realized this is a boating forum....
    Old 02-18-2022, 02:31 AM   #20
    BertBandit is currently offline
    Send BertBandit:
    No it's not OBD2. It is OBD1.
    I am replying with a new account because my old one does not work
    GaryDoug
    For Sale: Free 2000 z272 ladder lisapaul1 Mariah Parts For Sale & Wanted 2 05-20-2016 05:19 PM
    Free 1995 z220 talari project boat, portsmouth va. buchshot12000 Mariah Boats For Sale & Wanted 3 05-30-2012 03:12 PM
    free teal convertible top for '96 Talari BarkerD Original Mariah Talk 3 08-20-2010 12:11 PM
    1993 Mariah shabah I ended up getting it for free benelli5150 Original Mariah Talk 2 06-27-2010 11:38 AM
    There are 235 users
