porpoising real bad need help
Old 08-06-2017, 05:17 PM   #21
GaryDoug's Avatar
GaryDoug is currently offline
My Model: Z202
My Engine: 5.7L Bravo III
Send GaryDoug:
Default Re: porpoising real bad need help
Originally Posted by Brian Belcher View Post
Same here GaryDoug. I have the port side all the way up and the starboard down just enough to level it. I've monkeyed with them to see if I could get any more top end but the more I lowered, the more top end I lost.
"Level it" ?? Why? You may want to read this topic in another boating forum. You may have the same symptom if there is no explanation for the imbalance.
http://www.thehulltruth.com/boating-...l#post10546710
I should mention again, that I have the stainless versions and those have more adjustment capability (if you fix the design issues;-).
  • Old 08-06-2017, 09:43 PM   #22
    My Model: Z276
    Send Brian Belcher:
    Sorry dude, I've not made my point clear. What I was talking about, unstable, is only while underway. When I do get underway, I ask all my passengers to please stay in their seat ! The constant trim tab adjustments drive me crazy cause, I guess I'm Marine OCD. I want my boat perfectly level, side to side, while on plane ! (MOCD)
    BTW, my boat sits level while at rest.
    The best scenario I can come up with, to better explain what I'm TRYING to say about using trim tabs to the job of the engine trim.......
    Let's pretend you're cruising along and you run the port trim down to level the boat. You accidently run it down too far and now it's listing to starboard. Instead of raising the port tab, you run the starboard tab down to over come your too deep port setting. BUT, you run the starboard tab down too far and now you're listing BACK to port. SO, you run the port down even more.......You get point, right? The fix would have been to lift the port tab a little, in the first place.
    SO, your boat is porpoising and porpoising is from TOO MUCH UP TRIM. Lower your trim enough to stop the gallop.
    There's several times I look back at something that I opined on and wish I'd kept my opinioned mouth shut. This is one of those times !!
    Good day boys !
    elrack and berniethepilot like this.
    porpoising z210 jsewall82 Original Mariah Talk 33 06-08-2013 02:34 PM
    First Real Tow ShabahZ280 Trailering and Tow Vehicles 8 10-12-2007 02:37 AM
    the real Skipper of my boat...... Jeff Barnett Chit Chat/Off-Topic 6 09-11-2007 12:46 AM
    There are 307 users
