Winterizing FAIL
Old 06-08-2017, 02:28 PM   #1
kemper14 is currently offline
My Model: Z250 Shabah Limited
My Engine: 7.4L Volvo Penta
Send kemper14:
Default Winterizing FAIL
Well, I was very excited to get my 250Z LE in the water, started it up and was not happy to see water gushing from the engine. I found that one of the two brass freeze plugs were popped off the block on both sides.
I put them back in and did not find any leaks after several minutes of running. I plan to put it in the water and put some load on it.
Can anyone advise me on other failure modes and what to look for? Obviously, somehow it retained water after winterizing, and that water froze and pushed the plugs out. I did not notice any water in the oil after running, but I imagine that would take time to accumulate. Fingers crossed.
  • Old 06-08-2017, 02:46 PM   #2
    My Model: Z202
    Send Firestone:
    Default Re: Winterizing FAIL
    No fun. Did you winterize your boat or pay someone? Did the plugs go right back in or did you have to re-tap the holes? During your test run what did the temperature read?
    John
    Old 06-08-2017, 03:45 PM   #3
    Send kemper14:
    I will be running it tonight on the water, I ran it last night on muffs. It seemed to run fine, no sign of water but I'm curious what internal damage may have occurred that will not be visible. The plugs that popped out are not the drain plugs but the 2" brass pipe caps (core plugs). I was able to tap them back in fairly easily.
    Old 06-08-2017, 09:53 PM   #4
    zluvr is currently offline
    Gallery Images: 1
    Send zluvr:
    Block may have possibly internal cracking. Keep tabs on your oil. It will get milky if water mixes. I would replace the old plugs too. good luck with this!
    Winterizing a Mercruiser 4.3 Mike Holmes Mercury MerCruiser 1 10-20-2015 07:49 PM
    winterizing? Jmason03 Introductions 1 11-08-2012 02:53 AM
    Winterizing husker_fan General Maintenance 6 09-13-2012 01:52 PM
    Winterizing 496 Mag H.O. Tvacek Mercury MerCruiser 3 10-31-2008 07:56 PM
    Winterizing Tom General Maintenance 7 09-14-2008 04:21 PM
    Total Threads: 13,324
    There are 338 users
