5.7L oil change method
Old 04-08-2017, 07:05 PM   #1
GaryDoug's Avatar
GaryDoug is currently offline
My Model: Z202
My Engine: 5.7L Bravo III
Send GaryDoug:
Default 5.7L oil change method
Guys,
I don't know when the last oil change occurred on my boat so I think I should do it soon. I have the new filter ready and now want to know how you guys do the oil change. Do most of you use a manual pump pipe through the dipstick tube method? If so, what kit do you recommend? Do you perform the change with the engine warmed up already? Any tips for minimizing the oil leakage with the upside down filter on the top bracket? Thanks
Gary
  • Old 04-08-2017, 07:58 PM   #2
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Default Re: 5.7L oil change method
    Aha, I just noticed the "garden hose" fitting on the end of the dipstick tube. So maybe the Mercury or Jabsco pump?
    Old 04-09-2017, 02:59 PM   #3
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    I warm up the engine and use a Jabsco pump to suck out the oil through the dip stick tube.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    GaryDoug (04-13-2017)
    Old 04-09-2017, 03:07 PM   #4
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Thanks Steve,
    Do you think the Jabsco pump is better than the similar (and slightly cheaper) Mercury pump?
    Old 04-09-2017, 03:11 PM   #5
    My Model: Z280
    I've never used the Merc pump but have used my brass Jabsco pump for 20+ yrs.
    GaryDoug likes this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    pllevine (04-18-2017)
    Old 04-18-2017, 02:49 PM   #6
    Something interesting to add to this topic: I used a pump on my 7.4MPI and decided to pull the drain plug afterwards to see how much oil was being left in the pan. Much to my surprise there was less than a 1/4 quart that came out of the bottom drain plug. Moral of the story- the suction tube works just a good and its much more easy to do!
    Hudson River Steve likes this.
    Old 04-23-2017, 01:38 AM   #7
    Captainbob is currently offline
    My Model: shabah212
    My Engine: 5.7 alpha
    Send Captainbob:
    ive used both the manual pump and electric i found the manual is great just have rags,disp gloves, and and a large capable container, ziplock bag
    Old 04-23-2017, 01:49 AM   #8
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    I'm not so sure about the disposable gloves. The pump's brass body was hot as heck, maybe some heavy duty insulating gloves would be best. I did buy the Quicksilver version pump and the removable rubber end pieces leaked quite a lot of hot oil if I wasn't gentle about gripping it. It went fairly quickly but it only got about 4 quarts out (including the filter's oil) and I thought this 5.7 had more like 5 1/4 quarts.
    Thank you GaryDoug for this useful post!
    ElectricGuy (04-23-2017)
    Carb change 4.3L Andy b Volvo Penta 7 06-21-2013 10:48 PM
    oil change wlake73 Introductions 7 10-20-2010 04:43 AM
    Oil change Mark Mercury MerCruiser 2 02-18-2008 11:38 PM
    There are 192 users
