oil change
Introductions
Old 10-13-2010, 07:17 PM   #1
wlake73 is currently offline
My Year: 2007
My Model: sx21
My Engine: v-6 alpha I
Send wlake73:
Default oil change
is a can of motor flush advisable prior to oil change? 2007 sx21 merc v6
  • Old 10-16-2010, 05:44 AM   #2
    Oregondunes's Avatar
    My Model: Z302 Bow Rider
    My Engine: 7.4 bravo3
    Gallery Images: 36
    Send Oregondunes:
    Default Re: oil change
    how old, black and grungy is your motor oil ?
    the only time you need something like that is in a motor that hasnt had an oil change in like 5 years. If you think you wanna flush the engine, drop in a gallon of diesel before you change it. let the engine IDLE til warm, then drain.
    After refilling the oil, startup and let idle til warm again, then change the filter only one more time and your ready. Dont forget to check the level and add after the last filter change.
    2000 Z302 Bow Rider
    Old 10-17-2010, 07:47 PM   #3
    My Year: 2007
    My Model: sx21
    Send wlake73:
    thanks, oil is one season and clean. but hi revving boats i thought may need more care. 09 was first change since new in 07 after 20 hours and it was black but flowed smoothly.
    Old 10-17-2010, 09:19 PM   #4
    Gallery Images: 36
    Send Oregondunes:
    Don't get sucked into snake oil gimmicks. Sure if you got a boat that after 5 years and had never been serviced and the oil looked like fudge, then I'd say YEAH use something. But dumping a couple quarts of diesel in her and letting her warm up in the driveway before you drain her wouldn't hurt. I'd stil swap filter after a change and a warm up tho.
    2000 Z302 Bow Rider
    Old 10-18-2010, 08:43 PM   #5
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    What does the diesel do to help "flush" the oil?
    Old 10-18-2010, 08:49 PM   #6
    Gallery Images: 36
    Send Oregondunes:
    Dilutes or thins the oils and any deposits. If there is any build ups they will flush out. Though by diluting the oils they don't offer much protection. Don't rev the motor. Let idle only.
    2000 Z302 Bow Rider
    Old 10-20-2010, 01:45 AM   #7
    Dredd's Avatar
    Send Dredd:
    Hrm, makes sense I just hadn't heard of it before. Sounds scary though.
    Old 10-20-2010, 04:43 AM   #8
    Gallery Images: 36
    Send Oregondunes:
    Old skool
    2000 Z302 Bow Rider
    Oil Change Time What Oil to use? Nathan5678 General Maintenance 2 05-16-2010 03:19 AM
    Want to change the Sunbrella top to the latest version DaveC Sea Fox - Mariah Talk 2 04-22-2010 01:27 AM
    MerCruiser 4.3LX Gen II Outdrive Fluid Change daveraymyers General Maintenance 0 10-12-2009 03:42 PM
    Oil change Mark Mercury MerCruiser 2 02-18-2008 11:38 PM
    There are 337 users
