Stereo upgrade
Old 08-16-2016, 04:34 AM   #11
chrissbee77 is currently offline
Send chrissbee77:
Default Re: Stereo upgrade
Baholtz, I have a 12 sub 6 speakers and a 2,000 amp. Loudest damn boat on the water. You have plenty of room for a small sealed enclosure in the back engine area.
  • Old 08-17-2016, 03:06 AM   #12
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Ok. I've started the installation. Definitely not plug and play with my unit. I've been slicing wires. The aluminum trim plate can't be used without cutting it. Looking for suggestions on how to trim out the opening and make it nice.
    Old 08-17-2016, 03:13 AM   #13
    tdicamillo is currently offline
    My Model: Z222 Shabah
    My Engine: 7.4L Bravo I
    Send tdicamillo:
    Post a pic and we will help with some recommendations.
    Old 08-17-2016, 05:31 AM   #14
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    Originally Posted by baholtz View Post
    Phil,
    I'd love to see pictures of your install. Just got done replacing the stock 5-1/4" with 6x9's under the helm. Those are powered by a Pyle 400 watt amp, my fronts are 2 JBL 6-1/2" powered off the deck. I tried to remote switch a Plye 240 amp off my accessory switch to my tower speakers, but I haven't been able to make it reliable. I'm thinking I've got a bad amp. Mounted my amps on the storage side of the cover under the drivers seat...
    Would love some more bass, but we load the back of the boat so full of stuff getting to the beach - I don't think I can fit anything in there....
    I'll try and get some photos but I can assure you that they won't be that exciting. I don't have anything as cool as a tower. Matter of fact, I don't even have an interior in the boat right now. Most of it is in my garage. And I've had to take a three week break from working on my 202.
    1998 202 Shabah 5.0L Alpha 1
    Phil Levine
    1998 202 Shabah
    Old 08-17-2016, 02:03 PM   #15
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    Got the photos in my Drop box, but I can get them to appear, I just get a black box with an x in it.
    I'm dealing with a square opening in the fiberglass. I need to either cut out the original aluminum back plate to fit the hole or come up with some time of trim to cover the screw holes from the old back plate.
    Thank you Paul F for this useful post!
    pllevine (08-17-2016)
    Old 08-17-2016, 03:19 PM   #16
    pllevine's Avatar
    Send pllevine:
    Paul - Just out of curiosity.... Are you using a DIN radio install kit?
    Phil Levine
    1998 202 Shabah
    Old 08-17-2016, 03:49 PM   #17
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    I guess not. All I've got to work with is a hole in the fiberglass.
    I googled DIN installation kit and it looks like they are specific to the model of the auto?
    Guess I need some expert advice on what kit I need for a Kenwood stereo for boat applications.
    Old 08-17-2016, 04:31 PM   #18
    pllevine's Avatar
    Send pllevine:
    Usually, the radio comes with a DIN frame that gets inserted into the dash cutout first. It gets secured into the dash cutout and then you insert the radio into the frame and secure it to the frame.
    Phil Levine
    1998 202 Shabah
    Old 08-17-2016, 09:10 PM   #19
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    I talked to a friend who is a metal fabricator and he's going to water jet the hole in the original aluminum plate to fit the new unit! Should work out great!
    Old 08-18-2016, 07:06 AM   #20
    baholtz is currently offline
    My Engine: 305
    Send baholtz:
    Left side is stacked with dump trucks and squirt guns, right has a milk crate with extra prop and tools and stacked to the bottom of the sun pad with camp chairs.
    Basically, not going to fit. Need a bigger boat.....
    stereo/ switch panel upgrade Txtruckerpaul Original Mariah Talk 7 12-11-2013 01:13 PM
    Stereo upgrade smokey9015 Original Mariah Talk 12 11-07-2013 05:40 AM
    stereo upgrade Oregondunes Projects 13 11-23-2012 04:07 AM
    Anyone upgrade the stereo in a 96 Shabah 180? MW Mariah Original Mariah Talk 3 08-01-2012 08:44 PM
    Looking to upgrade bpfirrman Mariah Boats For Sale & Wanted 4 07-01-2008 10:03 PM
    Total Threads: 13,324
    There are 388 users
