Shore power ?
Old 08-18-2016, 02:26 PM   #1
96MariahZ220 is currently offline
My Model: Z272 SHABAH
My Engine: 502 MAG MPI
Send 96MariahZ220:
Default Shore power ?
I have a 1996 Z272 Shabah Bow Rider and it has Shore Power hookup. However, i am trying to determine if it has some sort of battery charger/tender from the factory? I found an old post about this and there was only one reply and didn't give much information. I hate to post another question about this but i want to be sure before i wire in my nice charger/tender that i had off my old boat that i saved. I would rather use the one i have instead of what is on there. I have also seen that the shore power only runs the outlet that is on the boat? Thanks for the input.
  • Old 08-18-2016, 06:18 PM   #2
    Default Re: Shore power ?
    Which "shore power" are you referring to? The large yellow 30 amp cables that attach to the dock power supplies, or a simple 3-prong (like standard extension cord size)? I know the majority of the cruisers and cuddles had true 30amp shore power which used the large yellow cable. The bowriders, if I remember correctly may have only had a battery tender 3-prong port which is located on the transom. I had this on my Z250, and it's basically just for plugging in the battery tender/maintainer which the boats were equipped with into standard 110v power (such as in a garage or storage facility).
    shore power fldoctor Original Mariah Talk 10 12-17-2012 04:37 PM
    Shore Power Minnox Original Mariah Talk 1 12-10-2011 12:12 AM
    shore power tazzyou Original Mariah Talk 7 04-03-2011 11:37 AM
    Shore power question Merrick6917 Original Mariah Talk 1 05-25-2009 05:25 PM
    shore power huj Original Mariah Talk 1 05-03-2009 01:57 AM
    Total Threads: 13,324
    There are 327 users
