Rookie Owner of 1992 Mariah 1900Z
Old 06-28-2016, 12:10 PM   #11
Hunter12345's Avatar
Status: Silver Contributor
Gallery Images: 2
Send Hunter12345:
Default Re: Rookie Owner of 1992 Mariah 1900Z
Originally Posted by Brian Belcher View Post
NOT THE OWNERS MANUAL !! It is the repair manual for your engine. You can get the Mariah manual on here by being a contributor, which pays for the site.
(I know Shabah, I PROMISE I'll buy a membership on the first of next month !!!!)
Please make a contribution. I have literally over run this site with my aimless meanderings but I'm retired and really like TRYING to help y'all out. So, any monetary contributions will keep this open and for me, a place to irritate the old salts.
When i made a contribution i got brand new captains chairs....[emoji12] lol
'98 shabah 180
5.7l 350 mag
Bravo III
  • Old 06-28-2016, 12:18 PM   #12
    Gallery Images: 2
    Send Hunter12345:
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 06-28-2016, 12:52 PM   #13
    rogers17 is currently offline
    My Model: 1900Z
    My Engine: mercruiser 4.3 V6
    Send rogers17:
    I will also make a contribution after next payday! I need this site! My bad, I have the owner's manual but thank you for the service manual! I will be doing some troubleshooting this week in the evenings and hope to take her back out on Saturday. I will update as to what exactly we found and if we can get her to plane out!
    CHICKS75 likes this.
    Old 06-28-2016, 02:35 PM   #14
    Shabah93 is currently offline
    My Model: Shabah 198
    My Engine: 5.0 EFI OMC Cobra
    Send Shabah93:
    Hello new Mariah owner.
    How many people did you have in the boat when you couldn't get it on plane? Was power smooth and did you feel thrust as you throttled up slowly?
    Old 06-28-2016, 02:38 PM   #15
    My Model: 1900Z
    Send rogers17:
    The first outing there was four of us, the second outing there was 7 of us. I talked to the prior owner and he said that he had the same problem at first and he simply did not have the prop all of the way down. I cannot imagine that would be the problem I am having unless the prop lowers really slowly. The boat accelerates well with throttle at about 1/4, slowly try to increase speed and it does a little bit, but then tops out at maybe 15mph and sounds like she is running hard. If you try to gun it from 1/4 to full, she let's out one backfire and I have to throttle down.
    Old 06-28-2016, 03:48 PM   #16
    Gallery Images: 2
    Send Hunter12345:
    Timing advance, or compression.... Time to go back to basics....
    Compression test, check timing (including advance), change fuel filters (including any in the carb)....
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 06-28-2016, 03:52 PM   #17
    My Model: 1900Z
    Send rogers17:
    All of this was just taken care of in May of this year. Prior owner had boat out 4 times this year and it was just fine, I am beginning to think it is simply me being a stupid rookie, but I am learning quite a bit about things on the boat!
    Old 06-28-2016, 03:53 PM   #18
    Gallery Images: 2
    Send Hunter12345:
    Above was a quote from a forum where someone had the exact same issues, turned out to be timing and filters.
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 06-28-2016, 05:09 PM   #19
    My Model: Z276
    Send Brian Belcher:
    Are you up on the use of trim while driving ? Do you know it's use ?
    Old 06-28-2016, 05:12 PM   #20
    My Model: 1900Z
    Send rogers17:
    Yes, I am familiar with the trim. We have been playing with it to see if we could get it to plane off. I am going over tonight to do some troubleshooting on the boat to check and see if the trim is actually trimming down all of the way or if it is getting stuck somewhere. It trims up perfectly
    Just Purchased 1992 Mariah 1900Z dlsuhr Introductions 14 07-12-2014 01:30 AM
    For Sale: 1900z 1992 windsheild rutrut Mariah Parts For Sale & Wanted 0 04-13-2014 06:52 PM
    1992 Mariah 1900z Faerbairn Introductions 2 11-23-2011 09:02 PM
    mariah talari 180 new owner rookie telinehan Introductions 1 07-18-2011 02:26 PM
    decal for my 1992 Mariah 1900Z Dave V Introductions 1 07-15-2010 09:53 PM
    There are 320 users
