1992 Mariah 1900z
Introductions
Old 11-23-2011, 05:08 PM   #1
Faerbairn is currently offline
My Model: 1900z
My Engine: 4.3L, Alpha One
Send Faerbairn:
Default 1992 Mariah 1900z
Where can I find out what HP is the engine?
Mercruiser GM V-6
Serial # T12172KR
Also, what generation is the outdrive?
Outdrive: Alpha One
Serial # OL981578
Did the engine come stock with a Edelbrock 4 barrel carb? Serial # 1406 7129
Did the boat come with the 4 blade SOLAS prop on it? # (M) E4x14.25x19R
I got it to fire up with a new tank of gas, new filters, and an auxilary 12v fuel pump. My plan is to change the gear oil in the outdrive, engine oil & filter, spark plugs, top off the power steering fluid and the outdrive lift motor.
The fuel pump that wasn't working is a Carter P/N 152-875. I can not seem to find the same one to replace it. Can I use a standard 12v fuel pump in its place?
Do I need to replace the impeller? It is running at 165 degrees on the hose.
Anything else I should do or check before I take it out?
Thank you for your help.
  • Old 11-23-2011, 08:56 PM   #2
    Default Re: 1992 Mariah 1900z
    I'll try to answer your questions in order since i see that no one at iboats.com answered these questions for you.
    Likely 190hp
    Alpha 1, Gen 2
    Not sure if it was an Edelbrock but that's unlikely. It did come with either a 2bbl or 4bbl carb.
    No. Likely came with a 14.25 x 19" 3 blade aluminum.
    Unsure about the fuel pump but i understand that a Carter model 4389 is the direct replacement. Will leave that one to mechanics here on our site. Here's a link to a vendor.
    If you dont know when the impeller was last replaced, then i would suggest that you do it now.
    btw....welcome aboard.
    Old 11-23-2011, 09:02 PM   #3
    My Model: 1900z
    Send Faerbairn:
    Thank you MikeyT
    1992 Mariah 2000Z depman160 Original Mariah Talk 12 04-03-2014 03:54 PM
    decal for my 1992 Mariah 1900Z Dave V Introductions 1 07-15-2010 09:53 PM
    1992 MARIAH MX 19 for sale texasowner Mariah Boats For Sale & Wanted 0 01-07-2009 01:51 AM
    There are 258 users
