New owner help Identify boat
Old 06-20-2016, 02:36 PM   #1
Shabah93 is currently offline
My Model: Shabah 198
My Engine: 5.0 EFI OMC Cobra
Send Shabah93:
Default New owner help Identify boat
Hello,
I just purchased a 1993 Mariah. Title states it's a Shabah 198 and the HIN# matches the title. Only issue is while looking at other Mariah owners pictures I am questioning the model # of my boat. I have more pics in my post in the introduction section of the forum.
I saw a Talari 200 that looks exactly like mine.
curious to hear your thoughts.
Thank you
  • Old 06-20-2016, 05:13 PM   #2
    Default Re: New owner help Identify boat
    Shoot me a PM with your HIN# and I'll look it up on the factory build sheets.
    Old 06-20-2016, 06:37 PM   #3
    Send Shabah93:
    Thank you very much, I will get that info as soon as i get home.
    I will also be tearing off the outdrive to inspect bellows, gimbal bearing, u-joints and shift cable. anything else I should inspect while it's apart?
    Old 06-21-2016, 01:45 AM   #4
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    High gunnel that run the windshield lines makes it a Shabah. Talari has lower sides. Looks like a Shabah.
    Sent from my XT901 using Tapatalk
    Old 06-21-2016, 01:54 AM   #5
    Send Shabah93:
    Thanks Paul, I would not think the title would be incorrect but Mariah has very similar lines and interiors in their boats.
    Old 06-21-2016, 01:59 AM   #6
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    The only difference is the deck mold. The bottom hulls and interiors are exactly the the same.
    Firestone and Shabah93 like this.
    Old 06-21-2016, 01:59 AM   #7
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    Mine is a Talari
    Old 06-21-2016, 02:09 AM   #8
    Send Shabah93:
    That's great. Now on to my next task. Tore outdrive off and found oil/grease and water in driveshaft bellow. U-joints have surface rust but still feel smooth with no binding. I examined bellow very closely and couldn't find any holes or tears. A little dry rot but that's it.
    Filled transom with hose and no leaks, felt under y-pipe and it was smooth and rust free. No idea how water made its way into driveshaft bellow. Ordering new bellow and bearing tonight and willl do more testing when it's all back together.
    Any thoughts would be appreciated.
    Old 06-21-2016, 12:02 PM   #9
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Unless they are in perfect shape, now is the time to replace the trim switch and sensor.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 06-21-2016, 01:47 PM   #10
    Send Shabah93:
    Steve, Thanks for the tip. I will look them over.
    Prop Guru's... help me Identify this Prop - pics attached nglauer Prop Talk 19 06-19-2013 06:25 AM
    The joys of being a boat owner of a used boat OFD4546 General Maintenance 1 09-12-2012 06:32 PM
    Help me Identify this part Mbaumy Original Mariah Talk 13 07-24-2011 03:15 AM
    Can you identify? Maddog Introductions 6 08-15-2010 02:27 AM
    How do I identify the cylinder numbers on a 5.7 EFI? DGR-Z246-98 Original Mariah Talk 2 04-30-2009 12:05 PM
    There are 225 users
