New owner help Identify boat
Old 06-25-2016, 07:30 PM   #11
My Model: Z276
Send Brian Belcher:
Default Re: New owner help Identify boat
Replace the bellows and trim sensors now ! There are kits that have everything that you need,minus a few special tools. If the upper gimbal is not rock solid, now is the time to address this. Do not torque the gimbal u joints over 50 pounds. You will Crack the gimbal or break the u joint. Cranking on the u joint will not close the gap if the gimbal is worn out.
Last edited by Brian Belcher; 06-25-2016 at 07:34 PM. Reason: Trying to use a new tablet and it sux
    Prop Guru's... help me Identify this Prop - pics attached nglauer Prop Talk 19 06-19-2013 06:25 AM
    The joys of being a boat owner of a used boat OFD4546 General Maintenance 1 09-12-2012 06:32 PM
    Help me Identify this part Mbaumy Original Mariah Talk 13 07-24-2011 03:15 AM
    Can you identify? Maddog Introductions 6 08-15-2010 02:27 AM
    How do I identify the cylinder numbers on a 5.7 EFI? DGR-Z246-98 Original Mariah Talk 2 04-30-2009 12:05 PM
    There are 543 users
