Lowrance 3500 depth gauge
Old 06-14-2016, 07:21 PM   #1
CHICKS75's Avatar
CHICKS75 is currently offline
Status: I got this...
My Model: 210 Z L.E. SHABAH
My Engine: 5.7 Alpha-One Gen II
Gallery Images: 15
Send CHICKS75:
Default Lowrance 3500 depth gauge
So, another issue I have is my Lowrance 3500 gauge is on its last leg. At least 3-4 of the LED tick marks that make up the numbers are burnt out.
My question is what have you guys used to replace this item? I want to stay with the gold bezel theme.
Could I use the same transducer by splicing into the wire?
1998 Shabah 210Z L.E. 5.7L, Alpha One gen II
Thanks all!
  • Old 06-15-2016, 07:17 PM   #2
    Default Re: Lowrance 3500 depth gauge
    Unfortunately, replacing it is the only option. Lowrance discontinued these many years ago, and also hasn't serviced them for years. To replace, you'll have to buy a whole new system, including the transducer , since the Lowrance 3500's transducer operates in a frequency band not compatible with any other equipment. Occasionally you'll be able to find a Lowrance 3500 on eBay, but because these are in such high demand, they have been known to fetch hundreds of dollars for used units...
    If I remember correctly, the later model Mariahs used Faria depth gauges, because they had the gold bezel and a similar look.
    Good luck!
    CHICKS75 (06-16-2016)
    Another Lowrance 3500 Tale of Woe pllevine General Maintenance 9 01-03-2016 11:21 PM
    Engine Hour Gauge and Depth gauge J Thornton Original Mariah Talk 5 08-21-2013 01:45 AM
    For Sale: Lowrance Factory Depth Finder Bezel ColoradoDiablo Mariah Parts For Sale & Wanted 0 12-29-2011 11:47 PM
    1993 2350Z Transducerfor Lowrance 3500 Tawakoni Paul General Maintenance 1 06-27-2011 07:51 PM
    There are 311 users
