Another Lowrance 3500 Tale of Woe
General Maintenance
Old 08-25-2015, 08:39 PM   #1
pllevine's Avatar
pllevine is currently offline
My Model: 202 Shabah
My Engine: 5.0L Alpha
Send pllevine:
Default Another Lowrance 3500 Tale of Woe
First, I can say that I read all of the related posts about the OEM Lowrance 3500 depth finder on this group, so I've been thinking about wax toilet rings and replacement units. I really would not go to a transom mount, at this point....
I took my 202 out a couple of weekends back and hit the power switch for the depth finder. It powers up but alternates quickly between feet and meters and the reading is erratic. And that damned buzzer won't stop. Is the unit blowh, the transducer messing up, or am I missing something?
Thanks in advance for your assistance.
Phil Levine
1998 202 Shabah
  • Old 08-26-2015, 03:43 AM   #2
    nkhagen is currently offline
    My Model: Z302
    Send nkhagen:
    Default Re: Another Lowrance 3500 Tale of Woe
    When my sounder failed it just wouldn't maintain a steady or accurate reading. When I removed it I found it was cracked. The head unit never alternated between feet and meters.
    Old 08-29-2015, 12:00 AM   #3
    pllevine's Avatar
    Send pllevine:
    I called the 800 number for Lowrance this morning. I was looking for help in diagnosing my issue. The customer service representative thought that I had a 3500C plotter. I got the idea that he was speaking about another model when he spoke about "seeing the U.S. Map" during the reboot.
    I checked that hockey puck transducer today and it is securely epoxied to the bilge depression. I am thinking that either the left button contact is stuck, even though I was wiggling it, or the entire head unit is toasted. I was at West Marine looking at a Hawkeye in their showroom for $100. It's only $10 more than eBay. I think I will look for an OEM 3500 head unit and then if I can't find it, it's be the Hawkeye.
    Phil Levine
    1998 202 Shabah
    Old 01-03-2016, 06:11 AM   #4
    Michaels1956's Avatar
    Michaels1956 is currently offline
    My Model: 2000 ZC
    My Engine: 5.7/V8 Alpha One
    Gallery Images: 4
    Send Michaels1956:
    Just wondering if the Hawkeye head unit will direct fit the old Lowrance model 3500 transducer wire connector and power connection? Will it fit in same cutout also? Thanks, Michael. :-)
    Sent from my SGH-I317M using Tapatalk
    Old 01-03-2016, 10:51 PM   #5
    pllevine's Avatar
    Send pllevine:
    Didn't go with the Hawkeyes after all. I decided to stay with the OEMs and bought a Faria Kronos 3 with in-hull transducer. I have not installed it yet. On my distant list of things to do.
    Phil Levine
    1998 202 Shabah
    Old 01-03-2016, 10:56 PM   #6
    My Model: 2000 ZC
    Gallery Images: 4
    Send Michaels1956:
    I want ro keep my Lowrance transducer that is fiberglassed hockey puck under the engine if possible so looking for plug and play alternative sounder since mine is toast in dashboard.
    Old 01-03-2016, 10:58 PM   #7
    pllevine's Avatar
    Send pllevine:
    A friend of mine that has been into boat fabrication and mechanics for a long time told me that a crow bar/chisel and one good hit from a hammer will remove the old transducer. It is epoxied in, not fiberglassed.
    Michaels1956 likes this.
    Phil Levine
    1998 202 Shabah
    Old 01-03-2016, 11:15 PM   #8
    My Model: 2000 ZC
    Gallery Images: 4
    Send Michaels1956:
    I may just buy a Lowrance 3500 on ebay if available. :-) It will be alot easier to plug and play than crow bar. But if there is an other unit that would fit the wire harness and transducer of Lowrance transducer already in boat that would be cool to. :-)
    Thank you Michaels1956 for this useful post!
    pllevine (07-16-2016)
    Old 01-03-2016, 11:19 PM   #9
    pllevine's Avatar
    Send pllevine:
    I spent last last years of formal education as an Avionics Engineering student. The Lowrance 3500 (if you can find it) goes for around $300. And that's IF your transducer functions properly. That's why I opted for a complete replacement with a new system.
    Phil Levine
    1998 202 Shabah
    Old 01-03-2016, 11:21 PM   #10
    pllevine's Avatar
    Send pllevine:
    Oh... And after looking around and doing some research, the only transducer compatible with a Lowrance 3500 head is another Lowrance 3500. They are very proprietary in construction, voltage, frequency
    Phil Levine
    1998 202 Shabah
    Wanted: lorance 3500 transducer ual777mech Mariah Parts For Sale & Wanted 3 07-27-2011 03:58 AM
    1993 2350Z Transducerfor Lowrance 3500 Tawakoni Paul General Maintenance 1 06-27-2011 07:51 PM
    Anyone else use the LMS-160 Lowrance? Z275 Original Mariah Talk 7 10-07-2010 07:58 AM
    1994 Barchetta 182 - $3500 blockp Mariah Boats For Sale & Wanted 3 08-05-2009 12:45 PM
    There are 308 users
