Starting problems
Old 09-18-2015, 02:59 AM   #1
TomB is currently offline
My Model: MX20
My Engine: 5.8 HO Omc King Cobar
Send TomB:
Default Starting problems
I just recently purchased this 1992 Mariah MX20 5.8 HO King cobra . I started it at home before going to the water . Got to the water and the thing would not start . The only way it will run at all is if I hold the key in the run position , soon as I let go of the key it quits . I have not done much troubleshooting yet because I don't know where to start . Any help would be appreciated .
  • Old 09-22-2015, 02:52 AM   #2
    Scotty's's Avatar
    Scotty's is currently offline
    My Model: Shabah z222
    My Engine: 6.2l bravo 3
    Send Scotty's:
    Default Re: Starting problems
    I believe on the king cobra they had a safety switch built in that the drive had to be at least half way down from the trailering position to let the motor run.
    Old 09-22-2015, 03:08 AM   #3
    Scotty's's Avatar
    Send Scotty's:
    From what I've read after a Google search I don't think they did.
    Old 09-22-2015, 03:10 AM   #4
    Scotty's's Avatar
    Send Scotty's:
    Will it rev up with the key held on?
    Old 09-22-2015, 12:59 PM   #5
    My Model: MX20
    Send TomB:
    Yes , It will rev up some , but runs rough . I believe I have chased it down to a bad fuel pump . I have a new electric one on order . Ordered it from amazon , it is eligible for prime shipping , but for some reason I will not receive it until Sep. 30 . I am a prime member . Hope this will correct my problem . Will update when I have it installed . Thanks for your interest .
    Old 10-05-2015, 11:35 PM   #6
    pkeane11 is currently offline
    Status: Gold Contributor
    My Model: shabah 190
    My Engine: 4.3 alpha
    Send pkeane11:
    Not sure about king cobra but I had a similar problem with my 4.3 mercruiser. Some engines with electric fuel pumps have low oil pressure cut out switches that tend to go bad. The switch is bypassed with the key in the start position to allow the motor to start. So if new fuel pump doesn't cure your problem check your engine wiring diagram to see if yours is equipped with one. Good luck
    Electrical starting problems Wong Original Mariah Talk 6 08-25-2014 05:00 PM
    Engine starting problems wackyd1 Original Mariah Talk 2 10-14-2012 02:58 PM
    starting problems sergio1209 Original Mariah Talk 4 04-13-2012 05:59 PM
    Ongoing problems starting 454 chriscorbett Mercury MerCruiser 15 08-29-2010 03:19 AM
    Intermittent Starting Problems Weezer Original Mariah Talk 4 11-20-2009 12:12 AM
    There are 202 users
