Fuel filter location
Old 07-28-2015, 05:41 PM   #1
Jeff202mariah is currently offline
My Model: 202 sahbah
My Engine: 5.0
Send Jeff202mariah:
Default Fuel filter location
Just bought 2000 mariah sahbah 202 need help location of fuel filter
  • Old 07-28-2015, 08:12 PM   #2
    cswinings is currently offline
    My Model: z240
    My Engine: 7.4
    Send cswinings:
    Default Re: Fuel filter location
    depends on what engine it has
    Old 07-28-2015, 09:25 PM   #3
    My Engine: 5.0
    Send Jeff202mariah:
    5.0 mercrusier
    Old 07-28-2015, 09:33 PM   #4
    My Model: z240
    My Engine: 7.4
    Send cswinings:
    Fuel injected or carb
    Old 07-29-2015, 04:59 AM   #5
    My Engine: 5.0
    Send Jeff202mariah:
    Throttle body
    Old 07-29-2015, 12:02 PM   #6
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    Hi... I just went through this fire drill of trying to troubleshoot my fuel system, thinking that I either had a clogged fuel filter or a stuck bee-bee in my fuel pickup ( it works as a one-way valve )....
    If you have the Mercruiser (GM) 305CID or 5.0L engine, then you'd also have a Mercarb 2 barrel carb (also known as a Rochester 2 barrel carb with a modified float assy in the bowl).
    There is no in-line filter, such as the one that you are used to seeing on a wheeled vehicle. There is a "rock-filter" at the fuel inlet to the carburetor. It has a spring assembly and sits inside the inlet. Take off the fuel line and then the nut behind it. The filter will be in there. There is good documentation on this website for the 5.0L Mercruiser engine and it shows an exploded view of this filter assy.
    There is also a fuel/water separator just below the electric fuel pump on the engine's lower left side (facing the engine). It looks like an oil filter but has nothing to do with the oil (The oil filter is in the rear of the engine and hangs down into the bilge area.
    I hope that helps, as I am a new Mariah owner too.
    Phil Levine
    1998 202 Shabah
    Old 07-29-2015, 12:16 PM   #7
    My Model: z240
    My Engine: 7.4
    Send cswinings:
    It depends on if it is fuel injected or carb'd. If it is carb'd it should have a spin off fuel filter/water seperator on the lower left of the engine (standing in front of engine looking towards back of boat) But if it is EFI, then it probably has a fuel filter cartridge that is inside of a canister.
    here is a good video of doing and EFI 5.0 liter on youtube. https://www.youtube.com/watch?v=8m7qNw1sWcA
    Old 07-29-2015, 01:21 PM   #8
    My Engine: 5.0
    Send Jeff202mariah:
    Thank you I find it and replaced it
    Fuel filter removal grommett Mercury MerCruiser 0 11-08-2014 03:28 PM
    Fuel filter location? sanukc Original Mariah Talk 1 04-30-2011 02:54 PM
    How to replace a fuel pump filter?? CARL SWINDLE General Maintenance 0 05-29-2010 03:03 AM
    Fuel Filter Replacement? MAJIC Mercury MerCruiser 0 05-01-2009 12:34 PM
    Fuel filter location on a 2000 7.4 MPI? Jeff Barnett Mercury MerCruiser 6 11-20-2007 09:15 PM
    Total Threads: 13,324
    There are 357 users
