new owner
Old 07-28-2015, 05:23 PM   #21
sallyw2 is currently offline
My Model: TALARIZ 200
My Engine: 205 hp
Send sallyw2:
Default Re: new owner
I need to make a better set up to change then no way to do in the water with the pins supplied
  • Old 07-28-2015, 05:24 PM   #22
    My Engine: 205 hp
    Send sallyw2:
    I have 20 ft . and it is about 2550 lbs
    Old 07-29-2015, 03:55 PM   #23
    This issue has been discussed previously a number of times. Generally the 80# tabs are too stiff for the 180 - 200 despite what the Nauticus site recommends. Exchange them for 60# tab arms from the manufacturer. The tabs will help but not completely fix a leaning problem though. You need to move items in the boat to help level out the load. As for the pin placement, it isn't necessary to have them in the same location. Being offset by one spot will help a bit with the leaning issue.
    Old 07-30-2015, 03:35 AM   #24
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Totally agree with MikeyT. The 80 lb struts are too much and is probably making your bow plow through the water which can make for a scary ride. Nauticus has exchanged for free in the past no problem
    Old 07-30-2015, 05:30 AM   #25
    baholtz is currently offline
    My Model: 202 Shabah
    My Engine: 305
    Send baholtz:
    When sitting in the water do you still list or is it just under power?
    I think it's a weight problem, and trim tabs might help but they won't fix it completely. I have them on my 202 and they help with planing out but I wouldn't trust them to fix a list.
    These boats should be pretty well balanced to start with, is it possible it might be retaining water under the floor?
    Old 06-19-2016, 12:54 PM   #26
    wickhoi is currently offline
    My Model: Talari
    My Engine: 5.0L bravo
    Send wickhoi:
    I'm glad I found this post. I have a '94 Talari 200Z and it has the same problem! I'm guessing it's a thing with that year/model. I have not tried the trim tabs but I will be installing them next. Thanks for the great info!
    There are 280 users
