new owner
Old 07-28-2015, 03:44 PM   #11
sallyw2 is currently offline
My Model: TALARIZ 200
My Engine: 205 hp
Send sallyw2:
Default Re: new owner
They are Nauticus sx 9.5x10 sx 9510-80
  • Old 07-28-2015, 03:49 PM   #12
    My Engine: 205 hp
    Send sallyw2:
    The tabs have some adjustments for different hole patterns . But with these on you were not able to do any adjustment with steering
    Old 07-28-2015, 03:56 PM   #13
    CHICKS75's Avatar
    CHICKS75 is currently offline
    Status: I got this...
    My Model: 210 Z L.E. SHABAH
    My Engine: 5.7 Alpha-One Gen II
    Gallery Images: 15
    Send CHICKS75:
    I have the same ones.
    they are not made to be a steering adjustment per-se, more of a planing & idle, no wake wandering correction.
    What hole location do you have currently have them?
    Old 07-28-2015, 04:16 PM   #14
    My Engine: 205 hp
    Send sallyw2:
    The tabs are nauticus sx9510-80 they do have different holes for adjustments.
    Old 07-28-2015, 04:27 PM   #15
    CHICKS75's Avatar
    Gallery Images: 15
    Send CHICKS75:
    I would start with the lowest hole setting and move out from there. mine is set on the middle.
    I have a 21ft (210) 6000# boat.
    With yours you might be at the last two holes (further away from the transom) since its a 180.
    Old 07-28-2015, 04:28 PM   #16
    My Engine: 205 hp
    Send sallyw2:
    I have them in the center holes
    Old 07-28-2015, 04:30 PM   #17
    My Engine: 205 hp
    Send sallyw2:
    Do you think they should both be the same ?
    Old 07-28-2015, 04:33 PM   #18
    CHICKS75's Avatar
    Gallery Images: 15
    Send CHICKS75:
    i would move them out two places (holes) and go from there, the 80# seems pretty stiff for a 180 so the outer most hole might achieve what you require.
    Thank you CHICKS75 for this useful post!
    sallyw2 (07-28-2015)
    Old 07-28-2015, 04:37 PM   #19
    My Engine: 205 hp
    Send sallyw2:
    They do help in planing .But i have the leaning problem. Mine is the only boat going down the lake at a 45 degree .
    Old 07-28-2015, 04:39 PM   #20
    CHICKS75's Avatar
    Gallery Images: 15
    Send CHICKS75:
    i mis-spoke the need to be in the most inner hole (closest to the transom)
    There are 280 users
