2000 222 prop
Old 04-23-2015, 12:13 AM   #1
busby1981 is currently offline
My Model: 222/Z222
My Engine: 5.7 alpha 1
Send busby1981:
Default 2000 222 prop
Hey guys I have a 2000 222 with a 5.7 liter and was wondering what prop ya'll are using for best top end speed. I don't pull skiers maybe a tube here and there. We just love cruising the lake I am running an ss 21 pitch now only hitting 4600 and about 43 mph. Wanting to buy a new prop and I'm thinking an ss 19 pitch.
  • Old 04-23-2015, 02:59 AM   #2
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Default Re: 2000 222 prop
    19 pitch will give you better acceleration, but don't think it still increase your speed. You definitely don't want to go higher than 21 as it will work your engine harder.
    Old 04-23-2015, 05:18 PM   #3
    baholtz is currently offline
    My Model: 202 Shabah
    My Engine: 305
    Send baholtz:
    I have a 202z with 5.0 We ran a SS 21 for a couple of years. Performance was lacking - partly due to elevation (4,700ft). Top end was somewhere around 46mph, but holeshot wasn't great, especially when loaded.
    Switched to a Mercury Hi-Five SS 19. Improved holeshot and top end stayed about the same. We've been happy with it, although it was expensive.
    Old 04-23-2015, 06:29 PM   #4
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    With a 19 pitch, your top rpm will probably bump to 4800 which is where you want it to be.
    Old 04-23-2015, 08:30 PM   #5
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    I would install Smart Tabs as a start.
    They are great for keeping on plane at low speeds for pulling tubes and you'll be amazed what it will do for your boat's performance.
    Search Smart Tabs on these forums and you'll find a lot of testimonials.
    Best thing you can do for your boat for under $200!
    Old 04-24-2015, 05:03 PM   #6
    cptbraine31's Avatar
    cptbraine31 is currently offline
    My Model: 221 Talari
    My Engine: 5.7 Mercruiser
    Send cptbraine31:
    Thumbs up Re: 2000 222 prop
    I fully agree with Paul about trim tabs. I install them on my last boat and this one and it is always a HUGE difference in performance. I may loose 1-2 mph on top end but it is worth all the benefits gained. Better hole short, better control, staying on plain at lower speeds.
    Turn your blower on 5 minutes before starting or while idle, if not, BOAT GO BOOM!!!
    Old 06-19-2020, 12:16 AM   #7
    222
    222 is currently offline
    My Model: 222BR
    My Engine: 5.7L GSI volvo sx
    Send 222:
    Have a 2001 Mariah 222 shabah volvo 5.7L gsi. sx outdrive
    running volvo penta s/s 3 blade prop 14. 3/4 x 19
    4200 rpm x 49mph w.o.t
    need to bring rpm up , still playing with different pitches.
    Old 06-19-2020, 02:27 AM   #8
    Read a couple of the STICKYS located in the Prop Talk Forum
    2000 250 Shabah VS 2000 Z250 Shabah Mhilly Original Mariah Talk 5 04-01-2015 08:00 PM
    2000 222 busby1981 Introductions 14 03-04-2014 12:26 AM
    Prop Guru's... help me Identify this Prop - pics attached nglauer Prop Talk 19 06-19-2013 06:25 AM
    2000 302 Motoxxx43 Mariah Boats For Sale & Wanted 3 04-29-2013 04:20 PM
    2000 Z182 prop recommendation needed Jgustman Prop Talk 3 08-13-2012 02:46 AM
    There are 349 users
