1996 shabah 180 dash switches
Old 06-17-2020, 05:39 PM   #1
pole trick is currently offline
My Model: 180 Shabah
My Engine: 4.3 Merc
Send pole trick:
Default 1996 shabah 180 dash switches
I can't figure out what the 2 acc switchs do on dash? The other 2 switches are bilge and courtesy lightss
Far as I can tell the 2 acc turn nothing on?
They look to be hook into wire harness but do nothing
Where do the wires go?
I want to hook boat plug light up and want to use one of those switches.
Do they have prerun dead end power wires run to front or rear of boat that you can tap into if needed?
  • Old 06-17-2020, 06:39 PM   #2
    Txfld is currently offline
    My Model: Shabah
    My Engine: 5.04 / Not sure
    Send Txfld:
    Default Re: 1996 shabah 180 dash switches
    Hey Pole,
    I just went through it with mine. I believe they could be your Navi lights and front light(forgot what the two headlights are called..oh, docking.) Anyhow, crawl under with 12v wire tester and see which lights it up and then follow. Tedious but worth it.
    Old 06-18-2020, 04:09 AM   #3
    My Engine: 4.3 Merc
    Send pole trick:
    I got screw driver out and took switch panel off from dash. The 2 acc switches are wired into harness for power in, but have no wire going back out. just a empty tang on each switch that has power when switched on.
    one switch has heavier gauge wire feeding it then the other.
    one switch must be light duty and one heavier duty?
    I got it figured out.
    thnaks
    Shabah Z255 1996 rocker switches brand? tpdtopcop Original Mariah Talk 3 06-16-2015 11:33 PM
    Wanted: 1996 Shabah z203 dash panel? DBshabahz203 Mariah Parts For Sale & Wanted 2 07-18-2012 01:13 PM
    Wanted: I need dash switches 94Z212 Mariah Parts For Sale & Wanted 2 10-06-2009 07:30 PM
    Dash Board Switches Lance Cassidy Introductions 1 08-29-2009 09:17 AM
    Dash Switches Douglas Alderman Original Mariah Talk 3 01-01-2009 03:25 PM
    There are 466 users
