engine block drain taps
Old 04-16-2015, 05:09 PM   #1
jsewall82's Avatar
jsewall82 is currently offline
My Model: z210
My Engine: 5.7L
Gallery Images: 17
Send jsewall82:
Default engine block drain taps
Indeed to replace my engine block drain taps. Pulled them out to winterized and they are in bad shape. Is it one size fits most? 5.7L mercruiser.
  • Old 04-18-2015, 03:04 AM   #2
    m&mmariah is currently offline
    Status: Gold Contributor
    My Model: 180 Shabah
    My Engine: 4.3 Mercruiser 4v carb
    Send m&mmariah:
    Default Re: engine block drain taps
    Are you talking about the small, blue plastic screw in plugs for draining water from the exhaust manifolds and the engine block? If so, I just replaced mine. I picked some up at one of the local boat dealers. He said they routinely replace them when they service the engine. The plastic tends to get brittle and break off. Anyway, they aren't very expensive, just a few dollars for four. Dealer has a "whole box of them".
    Old 04-18-2015, 04:38 PM   #3
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    Did mine this year too! One broke going back in! I think I plan on doing them every other year from now on...
    Old 04-20-2015, 03:16 PM   #4
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    The ones I am referring to are brass. They are for the block not the exhaust. The exhaust ones I replaced and they are plastic.
    Old 04-23-2015, 03:56 AM   #5
    Send m&mmariah:
    our boat is a '96 with the 4.3 V6. It originally had the brass screw plugs in the block as well, and they were a chore to remove. I stopped by one of the local MerCruiser dealers and bought a couple of brass adapters to replace the brass plugs. The adapters replace the block plugs, and the blue plastic wing nut plugs screw into the adapters. I basically updated our boat to the way the drains are done on the newer engines. Works great, and is quick to drain! Another labor saving upgrade is to replace the oil pan drain plug with the MerCruiser "oil drain hose." The hose screws into the oil pan and essentially replaces the drain plug bolt. The hose, which is a couple of feet long, has a brass screw plug on its end. When it's not in use, it just sits in the bottom of the bilge. When you're ready to change the oil, just thread the hose through the hull drain hole, unscrew the bolt on the end of the hose, and the oil drains out! Slowly, but it eventually all comes out. The bilge under the engine stays clean and oil free, and that alone was more than worth the small price of the hose/kit!
    Old 04-23-2015, 04:28 PM   #6
    jsewall82's Avatar
    My Model: z210
    My Engine: 5.7L
    Gallery Images: 17
    Send jsewall82:
    I have been looking at those hit I have found that they make two different ones for my model year and engine. I gotta figure out if I have the 1/2 by 20 or the 15 by 20 threads.
    Fuse block BDQ Mercury MerCruiser 1 07-11-2012 12:20 AM
    big block engine pull z272 barchetta Original Mariah Talk 2 05-09-2011 05:09 PM
    Cylinder block warrenpark65 Volvo Penta 0 05-28-2010 08:27 AM
    Engine Block Oil Stick Heater Douglas Alderman Boating 101 4 02-18-2009 05:17 PM
    Ski well drain/bilge drain jhaag41 General Maintenance 1 07-17-2008 10:09 PM
    There are 371 users
