1999 7.4 Merc Exhaust Flapper Replacement
Old 06-28-2014, 06:18 PM   #1
My Model: Z258
My Engine: 7.4 & Bravo 3
Send 99 Mariah 258:
Default 1999 7.4 Merc Exhaust Flapper Replacement
Had the boat on the hose after a day on the water and I heard a clicking sound from the exhaust and google informed me about these exhaust flappers......Has anyone done this on a 7.4(mine is a 1999).........Any tips or tricks.....Thanks in advance...
  • Old 08-08-2014, 08:48 PM   #2
    Hijo202 is currently offline
    My Model: Z241
    My Engine: 7.4 L Bravo I
    Send Hijo202:
    Default Re: 1999 7.4 Merc Exhaust Flapper Replacement
    I had the exact thing happen to me yesterday...I need the exact info...been googling it but not getting far
    Old 08-08-2014, 09:55 PM   #3
    My Model: Z258
    Send 99 Mariah 258:
    Hello.....
    Yea I googled and youtubed but only found videos of smaller motors but it's the same thing....it's easy...The flappers are installed inside the exhaust pipes.....they're located where the elbow after the riser connects to the y-Pipe on both sides. (On each side) loosen the 4 clamps holding the huge rubber connector ---- spray some wd40 on the y-pipe and try to slide the rubber connector down. Go ahead and take off the exhaust elbow as well.....You'll see the flapper sitting inside the y-pipe....If you see the new flapper you'll see they sit in place with two rubber plugs that hold both sides in place at the top of the y-pipe... Remove 1 side plug and try to pull the flapper out making sure not to drop anything down the pipe......it's simple but I have a lot of room in my engine compartment. Paid $65 each new flapper.......
    Willoughtree and Hijo202 like this.
    Thank you 99 Mariah 258 for this useful post!
    Willoughtree (07-25-2019)
    Old 08-09-2014, 12:16 AM   #4
    My Model: Z241
    Send Hijo202:
    Thanks for the reply!!!!
    z198 5.7L merc wredskinsfan32 Mercury MerCruiser 4 08-13-2013 03:43 PM
    Merc I/O - what goes down won't come up ATX_Diablo Mercury MerCruiser 8 07-11-2012 06:15 PM
    1999 merc 3.0l blown head gasket silver04roush Mercury MerCruiser 5 08-22-2010 05:12 PM
    Oil for my Merc 350 Jbetschart Original Mariah Talk 1 03-14-2010 09:43 PM
    There are 279 users
