z198 5.7L merc
Old 08-12-2013, 07:58 PM   #1
wredskinsfan32 is currently offline
My Model: z198 Shabah
My Engine: 5.7 merc
Send wredskinsfan32:
Default z198 5.7L merc
my exhaust blower quit working while on the water. When I got home I opened the hatch. When i turn on the blower switch a pump starts. this pump appears to have hydrolic lines and a reservoir.. my question what is this pump. it is on the port side
Last edited by ShabahZ280; 08-13-2013 at 03:41 PM. Reason: reposting question for archival purposes
  • Old 08-12-2013, 08:41 PM   #2
    Dozer's Avatar
    Dozer is currently offline
    My Model: Z202 shabah
    My Engine: 5.0 liter alpha 1
    Send Dozer:
    Should be your trim pump.
    Old 08-12-2013, 08:46 PM   #3
    My Engine: 5.7 merc
    Default Re: z198 5.7L merc
    why does it come on when i turn on the blower switch. the oil in the reservoir seems low and looks white. what type of oil is used????
    Old 08-12-2013, 10:06 PM   #4
    Dozer's Avatar
    Send Dozer:
    It shouldn't come on with the blower switch. Some wires must be crashed somewhere. If the oil is white it must have water in it. That's not good. Does that pump come on when you hit the trim button?
    Old 08-13-2013, 03:43 PM   #5
    Wredskinsfan32 erased his original post and marked this as "problem solved". I've reposted the original question for archival purposes just in case anyone else needs to find the answer to their questions.
    Merc I/O - what goes down won't come up ATX_Diablo Mercury MerCruiser 8 07-11-2012 06:15 PM
    Thoughts and info on a 1997 Z198 Limited EDition nhsd Original Mariah Talk 6 04-10-2011 12:49 PM
    Oil for my Merc 350 Jbetschart Original Mariah Talk 1 03-14-2010 09:43 PM
    There are 363 users
