LOUD Tapping Noise
Boating 101
Old 04-18-2014, 11:00 PM   #1
mmckenzie6 is currently offline
My Model: 202 shabah
My Engine: 5.7 L Bravo I
Send mmckenzie6:
Default LOUD Tapping Noise
I have a 1995 Mercruiser 5.7, Bravo One. Motor is fine, but there's a loud tapping noise in the top of the outdrive when gear is engaged. Only makes the sound when outdrive is raised and prop turning. Lower the drive and the noise stops.
Any ideas?
  • Old 04-19-2014, 01:51 AM   #2
    Default Re: LOUD Tapping Noise
    Sounds like the u-joints dont like to be run when the outdrive is in the up position and in gear. They are not designed to do that. Please stop unless you really want some damage to pay for.
    gahooligan (04-19-2014)
    Old 04-19-2014, 02:00 AM   #3
    Ditto
    Old 04-19-2014, 06:48 PM   #4
    I'd bet on U joints as well.
    Might want to check your trim limits if the normal operating range is making that noise. It could be possible it is not adjusted correctly. Then again, one shouldn't be operating the drive if it is trimmed up super high.
    Another idea may be gimbal bearing. Just something to consider.
    Old 04-19-2014, 06:50 PM   #5
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    Are we talkin up, or trailering position?
    Buzzing noise when battery connected speco1959 Mercury MerCruiser 3 07-17-2013 08:21 PM
    Engine noise Juno Original Mariah Talk 1 08-17-2012 02:44 AM
    Grinding noise when first put in gear Mariahmaroo Original Mariah Talk 12 09-08-2011 02:36 PM
    alpha one noise mwads275 Introductions 5 09-24-2010 12:53 PM
    Beeping Noise??? llcelebrity Original Mariah Talk 3 08-13-2009 04:34 AM
    There are 298 users
