carter afb (weber) carb factory jet sizes?
Old 05-26-2014, 03:40 PM   #11
Txtruckerpaul's Avatar
My Model: Z240 talari
My Engine: 7.4 bravo III
Send Txtruckerpaul:
Default Re: carter afb (weber) carb factory jet sizes?
I'm gonna try some new rods and new jets. Old jets look pretty bad from screwdriver damage and there no numbers on them at all, so I have no idea what size they are. Boat is back in the shop AGAIN. Got the prop seals replaced, now I have a whirring and ticking noise coming from somewhere in the upper drive or around the gimbal housing.
    7.4 carter AFB carb metering rod springs Txtruckerpaul Mercury MerCruiser 0 05-18-2014 09:49 AM
    Different Sizes? RARinger Original Mariah Talk 9 05-13-2014 10:33 PM
    weber carb help!!!! shonuff93 Mercury MerCruiser 3 08-13-2011 06:40 PM
    Prop Sizes ? karmann Prop Talk 0 06-22-2010 06:14 PM
    Weber Carb Fuel Filters MAJIC Original Mariah Talk 0 04-27-2009 05:15 PM
    There are 281 users
