weber carb help!!!!
Old 08-12-2011, 11:21 PM   #1
shonuff93 is currently offline
My Model: mx 19
My Engine: 4.3 v6
Send shonuff93:
Default weber carb help!!!!
Does anyone know where the ball bearing goes in a weber 9600 carb. Just recently did a rebuild and never saw the ball until I was cleaning up the bowl that I was soaking parts in. Went to dump it and there it was! Need help quick please!
  • Old 08-13-2011, 03:15 PM   #2
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    Default Re: weber carb help!!!!
    Sounds like a check ball, did u get a parts diagram with the kit? The one I am thinking of, take off the top of the carb, in the center front there will be 2 screws holding down a small cover, take it off, there is a hole under the small cover toward the back some carbs have a spring there, some have a little piece of metal, the only ball I know of goes under the spring or piece of metal
    Happy boating
    Dan
    Old 08-13-2011, 03:51 PM   #3
    My Model: mx 19
    My Engine: 4.3 v6
    Send shonuff93:
    I know exactly where you're talking about. It goes on top or under the spring?
    Old 08-13-2011, 06:40 PM   #4
    Send DFZ272:
    It goes under the spring. If a new one came in your kit, make sure u the old one isn't still stuck in the hole.
    Good Luck
    Dan
    what carb is it? coorsmgood Original Mariah Talk 2 08-24-2010 02:18 AM
    What Carb do I have? ggrims Mercury MerCruiser 3 06-12-2010 06:13 PM
    new carb ? boat man2 Original Mariah Talk 4 07-10-2009 06:14 PM
    Weber Carb Fuel Filters MAJIC Original Mariah Talk 0 04-27-2009 05:15 PM
    94 182 barchetta / b weber brett weber Original Mariah Talk 4 03-27-2008 02:31 AM
    There are 435 users
