7.4 running rich
Old 04-13-2014, 05:29 AM   #1
Txtruckerpaul's Avatar
My Model: Z240 talari
My Engine: 7.4 bravo III
Send Txtruckerpaul:
Default 7.4 running rich
Hi all. Got my 7.4 running with a rebuild kit in the weber/edelbrock carb. I set the floats to spec. Starts on first crank every time. Seems to be a little rich though, as I can smell it a little. Are the marine engines supposed to be a little on the rich side?
  • Old 04-13-2014, 02:42 PM   #2
    Default Re: 7.4 running rich
    Hey Paul ,
    Hook up a vacuum gauge to a vacuum port on the base of your Weber.
    Adjust the idle/air screws til you have optimum vacuum , that should solve it for ya.
    Old 04-13-2014, 02:44 PM   #3
    Send Txtruckerpaul:
    Ok Larry. I'll have to go to a plug on my intake to get some vac. My weber has no ports on it
    Old 04-13-2014, 02:46 PM   #4
    It should still work fine Paul
    Just make sure you keep the screws out the same number of turns , or at least very close.
    Old 04-13-2014, 02:50 PM   #5
    Send Txtruckerpaul:
    Gotcha. I prolly need to check the plugs and my timing too. I think that's the only two things I haven't looked at on this thing. I better get on the ball- weather is warming up quick here
    Old 04-13-2014, 03:05 PM   #6
    Your in the 80s already ain't ya?
    I'm jealous!
    Mariah1 likes this.
    Old 04-13-2014, 03:18 PM   #7
    Mariah1's Avatar
    Mariah1 is currently offline
    My Model: Shabah Z198
    My Engine: 4.3 Alpha1
    Gallery Images: 9
    Send Mariah1:
    Took mine out yesterday for about 2 hours..I love it when we can get back on the water.
    Old 04-13-2014, 03:26 PM   #8
    Yeah , yeah............rub it in Mariah1.
    Old 04-13-2014, 03:39 PM   #9
    Mariah1's Avatar
    Gallery Images: 9
    Send Mariah1:
    Just great day for the ride. She started her 21st year of service yesterday. My passengers yesterday could have cared less.
    Old 04-13-2014, 05:21 PM   #10
    Send Txtruckerpaul:
    We've had a few low 80's days already. Humid as all get out. Mosquitos and wasps are already out, some are big enough to carry a small dog away
    running........cool?? phillycincykid Original Mariah Talk 8 09-11-2012 01:05 AM
    Winterizing a non running 7.4... bblauvelt Mercury MerCruiser 1 12-04-2010 09:14 PM
    Help 454 Running bad??? karmann Original Mariah Talk 2 08-13-2010 10:49 PM
    Running very bad need help mike2828 Original Mariah Talk 1 11-19-2009 04:32 AM
    What prop are you running? KSP181 Prop Talk 12 11-20-2008 10:55 PM
    There are 319 users
