looking for advice for a tune up on 5.7 EFI Bravo III
Old 03-18-2014, 02:22 PM   #1
donly1's Avatar
donly1 is currently offline
My Model: 268 MCC
My Engine: 5.7 350 MAG EFI Bravo3
Gallery Images: 13
Send donly1:
Default looking for advice for a tune up on 5.7 EFI Bravo III
So its that time again. I own a 268MCC with a Mercrusier 5.7 EFI Bravo III 0L694819. This is the list I have so far, am I missing anything else, please advise. Do I have a thunderbolt ignition?
Oil Change with Filter 35-866340Q03
Fuel Filter 35-802893Q01
Distributer Cap 805759T1
Plugs 33-816336Q
Wires 84-816608Q83
5 quarts of Mercruiser Premium Gear Lube (Has anyone just drain the drive, and filled it through the reservoir? some are doing it to get all the air out)
Any advise on the impeller?
Any other advise on regular maintenance?
  • Old 03-18-2014, 08:43 PM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Default Re: looking for advice for a tune up on 5.7 EFI Bravo III
    I'd do the impeller as well. It's "supposed" to be every other year, but mostly depends on your water quality (muddy, sandy, shallow areas vs. clear, deep water). Looks like you're good with everything else!
    Yes, I believe you have Thunderbolt ignition. Depends on year.
    Don't forget wax, shampoo carpets, clean and protect vinyl, blah blah blah... everything else that never seems to get done!
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 03-19-2014, 02:04 AM   #3
    I would not suggest filling the oil through the res. There is a pump sold for this. It should be around $10.
    Gear oil info
    Old 03-19-2014, 12:22 PM   #4
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    You cannot fill the drive via the res. You must pump from the bottom of the drive up into the res to ensure there is no trapped air or else risk damage to your very expensive Bravo3 drive.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 04-13-2014, 02:37 PM   #5
    Txtruckerpaul's Avatar
    My Model: Z240 talari
    My Engine: 7.4 bravo III
    Send Txtruckerpaul:
    Moto and Steve, isn't the correct way to do this is to pump oil into the bottom drain plug with the vent plug open, then put the vent plug in when the oil starts coming out, and then keep pumping thru the drain plug until the reservoir by the engine is close to full?
    Old 04-13-2014, 02:45 PM   #6
    My Model: Z280
    Paul - you are 100% correct. I only fill the reservoir to the level that the post for the float is just covered. I like to leave room for the drive lube to expand. The drive fluid in my Bravo3 gets pretty hot pushing my Z280 and will expand and overflow if filled too high.
    Sent from my iPad using Tapatalk
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 04-13-2014, 02:48 PM   #7
    Send Txtruckerpaul:
    Ok Steve, thanks. I'll have to drain a little out of my reservoir, got it too full. All I need is a big messy spill back there from hot oil running out everywhere!
    Old 04-13-2014, 02:51 PM   #8
    My Model: Z280
    And of course the reservoir is located just above the exhaust manifold...lovely smelling smoke...like a dead dinosaur!
    Sent from my DROID2 using Tapatalk 2
    Mariah1 likes this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 04-13-2014, 02:52 PM   #9
    Send Txtruckerpaul:
    Yuk- that stuff stinks enough as it is fresh out of the bottle
    Old 04-16-2014, 04:54 PM   #10
    jayws6 is currently offline
    My Model: Z255 Shabah
    Send jayws6:
    I've only had our boat for one boating season so I don't have much experience with it but I filled through the lower drain plug until the gear lube came out the top vent plug. Installed both plugs and filled through the reservoir until it was almost full. There will be some air in between but it should get worked out. At least the B3 won't have any air in it. I was hesitant to fill past the vent plug not knowing if it would cause any issues.
    Sent from my Q10 using Tapatalk
    Tune up njc15880 Mercury MerCruiser 3 07-24-2013 12:29 AM
    Red 210 LE 7.4 Bravo 1 rayzorback Mariah Boats For Sale & Wanted 8 07-06-2013 12:27 PM
    Items for a Tune-up CARL SWINDLE General Maintenance 2 06-03-2010 10:53 PM
    Is this a good tune-up CARL SWINDLE General Maintenance 1 05-19-2010 02:35 PM
    Spring Tune up Paul Z Paul Z General Maintenance 0 04-13-2008 05:16 PM
    There are 278 users
