High RPM
Old 09-05-2013, 04:24 PM   #11
LifeIsGood is currently offline
Send LifeIsGood:
Default Re: High RPM
Guess that is what led me to believe I had used the wrong terminology. I have not run full throttle trimmed down. Original post:
WOT trimmed up would get me to 5k RPMs. Running with 19 [correction - 21] pitch prop. Had it out this weekend and noticed I was hitting 5k RPMs at only 3/4 throttle trimmed all the way down.
  • Old 09-05-2013, 07:56 PM   #12
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Originally Posted by blockp View Post
    I wouldn't think small burrs on the blades would have that much effect... unless you buried it hard and took some cupping out of blades or something like that.?
    you'd be surprised how much Cavitation a rough leading edge can cause!
    Cavitation occurs when pressure on the water across the blade’s surface is reduced to the point of becoming water vapour, forming bubbles.
    If these bubbles burst, they can cause a cavitation burn which can deteriorate the propeller’s surface and cause negative performance issues.
    As this condition can cause an increase in engine rpm, it’s often confused with ventilation.
    Old 09-05-2013, 08:29 PM   #13
    Send LifeIsGood:
    Thanks Andy b,
    I have experienced cavitation in the past but typically on a sharp turn. I do not believe that is what I am experiencing now though.
    I do appreciate the response.
    LifeIsGood
    Old 09-05-2013, 09:23 PM   #14
    Originally Posted by LifeIsGood View Post
    Thanks Andy b,
    LifeIsGood
    Sharp turns dont cause 'cavitation' but you can experience 'ventilation' during sharp turns.... as Andy noted, they are easily confused.
    Old 09-05-2013, 09:52 PM   #15
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    Thanks Andy b,
    LifeIsGood
    Ventilation is when air is drawn in around the propeller blades.
    Normally, this causes a gain in rpm, but a loss of speed, since the propeller blades are not biting clean water.
    This most commonly occurs during hard cornering or in certain water conditions, such as following seas.
    Old 09-05-2013, 10:03 PM   #16
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    If you look here you will see how the water vapour is formed on the blades edge.
    mikeyt likes this.
    High Five Prop rew10 Other For Sale 6 07-06-2012 01:38 AM
    high five prop Andy-Z202 Shabah Prop Talk 2 05-01-2012 03:15 AM
    WOT RPM's too high KeepitReal Mercury MerCruiser 4 07-29-2011 02:19 AM
    High-pitched alarm sound & high temp at high RPM petemcrunnel Original Mariah Talk 7 06-15-2011 05:57 PM
    High Five grommett Prop Talk 15 04-27-2011 07:08 PM
    There are 277 users
